Corner Beads - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 08:33 AM   #1
Rewards Points: 77
Corner Beads
Is there a preference for the type of corner beads? I bought some vinyl base ones at a box store. But I noticed that there were several other options including all metal ones and some that seemed like they were comprised of paper and maybe metal? Also, what is the best way to attached them to the corners. Drywall screws or nails? Thanks
RMCarner is offline   Reply With Quote
Old 05-24-2011, 06:43 AM   #2
Next Time...New Build
Rewards Points: 150
Depends on your application. For regular outside corners, I personally like the metal bead. They can be installed with either screws or nails (as long as the nails are made for it, not just any old 6p nail).
I have never used the paper type so I can only speak of what I have experience with.
RickyBobby is offline   Reply With Quote
The Following User Says Thank You to RickyBobby For This Useful Post:
RMCarner (05-24-2011)
Old 05-24-2011, 07:22 AM   #3
Rewards Points: 77
Okay. I just don't have a lot of experience with either/or.
Old 05-24-2011, 11:02 AM   #4
I make love to my walls
For a small job you should use metal. It's cheaper than no coat ultra flex which IMO is the best out there. Make sure if you use metal to first coat it with hot mud (durabond) any horizontals like under a beam or a soffit get a tape under them. Metal is prone to cracking much more so than paper
Arey85 is offline   Reply With Quote
Old 05-24-2011, 09:30 PM   #5
Rewards Points: 172
I didn't think they got screwed OR nailed......
nateshirk is offline   Reply With Quote
Old 05-25-2011, 11:40 PM   #6
Paper Laminated Metal Bead ONLY, EVER.
Glue it on with Taping Compound.
NEVER EVER USE METAL BEAD - PERIOD.
Dan - Drywall Taper / Finisher
dberladyn is offline   Reply With Quote
The Following User Says Thank You to dberladyn For This Useful Post:
RMCarner (05-26-2011)
Old 05-27-2011, 09:44 AM   #7
Drywall contractor
Rewards Points: 1,070
Paper faced metal bead is the best in my opinion...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-27-2011, 09:51 AM   #8
Rewards Points: 77
I hear you both. I was too lazy to take back the half dozen vinyl corner beads and get the paper faced ones. I thought: 'the hell with it' - either way, I got very little experience mudding corners and I can screw up just as well with one as opposed to the other. Some of the demos on Youtube by professionals raised my esteem for this type of work to a new level. They make it look so easy. I ran some compound over about 15' of corner bead using and 8" knife. My main concern is that I may have put on too much. Question: is the outside part of the corner supposed to be covered with compound on the first run?
Old 05-27-2011, 11:37 AM   #9
Drywall contractor
The very outside edge really doesn't cover with mud, it would get chipped off every time someone bumped it. Paint will cover it....
The Following User Says Thank You to bjbatlanta For This Useful Post:
RMCarner (05-27-2011)
Old 05-27-2011, 02:45 PM   #10
Rewards Points: 258
I used the vinyl base ones with no issues. No cracking.
jburchill is offline   Reply With Quote
Easy question...taping corner beads? tpagel Drywall & Plaster 6 05-18-2010 12:15 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
Replacing Drywall Corner Beads jodell8964 Building & Construction 2 03-15-2009 06:31 PM
Do I need to tape the flanges of the corner beads? SKINNY Remodeling 4 10-14-2008 07:23 PM
Best way to fix corner beads that are cracking? Git Painting 5 08-26-2008 11:52 PM
