Corner Bead Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 11:41 AM   #1
Corner bead question
Hi just some experience input.
I'll be doing outside corners for the first time using metal corner bead. I've seen both screws and nails used to install corner bead. Can someone explain if there are any benefits to using nails or screws and what size nails or screws would I use?
Aloha1 is offline   Reply With Quote
Old 02-16-2012, 11:45 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Screws are always better, but
either or. 1-1/4"
titanoman is offline   Reply With Quote
Old 02-16-2012, 12:00 PM   #3
Rewards Points: 14,026
I always use nails. The heads are flat so less change to have one sticking out and catching it as you try and finish it.
Less likly to buckle the metal causing a hump from over tightning.
Old 02-16-2012, 12:09 PM   #4
Disabled wood vet
titanoman's Avatar
I thought of that, but I also thought corners take a beating sometimes, less of a chance for nail-pops, especially if you don't tape the corner bead.
Old 02-19-2012, 07:51 PM   #5
Rewards Points: 512
i always use screws, way easier to fine tune then nails, and constantly check your gap with a drywall knife as you work down the corner bead
princelake is offline   Reply With Quote
Old 02-20-2012, 12:33 AM   #6
Disabled wood vet
titanoman's Avatar
Yeah. Don't push or pull the corner on too hard as the "bead" part of it needs to be higher than anything else (to the op).
Old 02-20-2012, 06:07 AM   #7
DIY staff
Rewards Points: 7,174
Nails --screws can pucker up the thin metal---
I use 1 1/2" small crown staples,myself.
Old 02-21-2012, 07:12 PM   #8
Drywall contractor
Rewards Points: 1,070
1-3/8" drywall nails for metal. The paper faced, metal reinforced bead you mud on has WAY less problems with cracking or "popping" loose down the road. That's all I use any more....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-21-2012, 07:46 PM   #9
DIY staff
I'm going to have to try that---
What is the best method for installing it?
Old 02-21-2012, 09:16 PM   #10
Drywall contractor
Just like you would a piece of tape on an inside corner. Run mud on either side of the corner. Place the stick of bead on. "Squeeze it into the mud. Wipe it down. If you dfo a fair bit of drywall work, buy an outside corner roller (all-wall.com) for about $70.00 if I remember correctly. Use the same process, but use the roller to "set" the bead in the mud, then wipe down. If you do a LOT of work, they make a hopper you can fill with mud and run the bead through to apply mud. Then stick it on, roll it and wipe down.
Old 02-21-2012, 09:38 PM   #11
DIY staff
I'll give it a try next time I do a room---Thank's
Metal corner bead vs Paper-Faced bead CMHbob Drywall & Plaster 6 04-09-2017 07:39 PM
Corner bead wraiththe Tiling, ceramics, marble 0 12-19-2011 10:37 AM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 12:45 PM
Ceiling corner bead kchopper Drywall & Plaster 8 03-18-2010 10:36 AM
Flared corner bead issue tripower Drywall & Plaster 2 02-28-2010 08:33 PM
