Corner Bead For Non-right Angles - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 05:59 PM   #1
Rewards Points: 1,062
corner bead for non-right angles
What corner bead should be used for angles that are not 90 deg? I have a couple of corners like that in my skylight shaft.
I remember seeing a metal-reinforced paper tape that can be cut with snips and has a crease so it can be adjusted. Is that what i should use?
Old 07-17-2012, 06:37 PM   #2
DIY staff
Rewards Points: 7,174
Metal corner bead comes in 45 degree--if that doesn't work--you can use the metal reinforced paper--
amakarevic (07-17-2012)
Old 07-17-2012, 07:19 PM   #3
Rewards Points: 512
you are thinking of no coat or strait flex and those would definitely work. there is also vinyl corner beads for different angles or theres the traditional metal corner.
princelake is offline   Reply With Quote
The Following 3 Users Say Thank You to princelake For This Useful Post:
amakarevic (07-17-2012), mae-ling (07-17-2012), oh'mike (07-17-2012)
Paper Faced Metal Corner Bead & Multiple Intersecting Corners Fire4Effect Drywall & Plaster 2 04-09-2012 09:53 PM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 12:45 PM
Metal corner bead vs Paper-Faced bead CMHbob Drywall & Plaster 4 04-24-2011 04:36 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
