Corner Bead - Metal Vs PVC - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 12:09 PM   #1
Corner Bead - Metal vs PVC
I had never heard of PVC corner bead, but just saw it on the HD website. Anybody know if it's any good? Pros? Cons?
gdoucette is offline   Reply With Quote
Old 06-07-2010, 06:14 PM   #2
Old School
Willie T's Avatar
I only use it for arches... the kind that is slit every inch or two. For the rest, I want good, hard metal.
Willie T
Old 06-11-2010, 03:28 PM   #3
Drywall contractor
Rewards Points: 1,070
Your best option is the "mud on" metal reinforce paper bead. It bonds to the drywall the entire length of the bead and has way less chance of "popping" down the road and more resistant to bending if bumped. It's all I use any more. Hd and Lowes sell it by the stick. Metal would be my second choice. Used the plastic arch bead once that was supplied by the customer. Didn't like it. Strait-Flex makes a mud-on arch bead that's much better in my opinion. Metal would be my second choice....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
attaching corner bead to metal studs ar2736 Building & Construction 2 10-28-2008 12:32 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
Corner Bead....Metal or Plastic? yummy mummy Building & Construction 2 01-23-2008 06:11 PM
Flexible metal corner bead? Worth using? yummy mummy Building & Construction 3 11-15-2007 07:09 PM
