Corner Bead Instead Of Baseboard Molding - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 08:59 PM   #1
Corner Bead Instead of Baseboard Molding
I have a loft and instead of baseboard molding I want to use L-bead cornerbead on the bottom of the drywall. There will be a 1/2" gap between the drywall and the wood floor.
Questions:
1. Steel or Vinyl?
2. Screws or Nails?
3. Are the screws/nails supposed to be secured through the drywall and into the framing?
4. I have steel framing, if the corner bead is supposed to be secured to both the drywall and the framing, obviously nails won't work, correct?
Any other suggestions would be appreciated.
Thank you for your help!
MartinD is offline   Reply With Quote
Old 08-04-2010, 10:25 PM   #2
Rewards Points: 256
http://files.buildsite.com/dbderived...ived300070.pdf
oldrivers is offline   Reply With Quote
The Following User Says Thank You to oldrivers For This Useful Post:
Axecutioner-B (08-04-2010)
Old 08-05-2010, 08:08 AM   #3
gmhammes's Avatar
i am curious to see how this turns out. Keep us posted!
gmhammes is offline   Reply With Quote
Old 08-07-2010, 01:03 PM   #4
Drywall contractor
Rewards Points: 1,070
I personally don't use plastic, but some people swear by it. The screws won't pull up in the drywall. You'll have to hit a stud....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-07-2010, 01:37 PM   #5
Electrician
Proby's Avatar
What is the purpose of this? Just for looks, or is this something to do with airflow?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-07-2010, 01:49 PM   #6
Drywall contractor
Shouldn't be any airflow if there's a bottom plate on the wall. I'm guessing just a different look???
Old 08-07-2010, 04:09 PM   #7
Rewards Points: 256
It does have a unique look not having trim , but another advantage is you dont have to worry about trim shrinking and expanding leaving those gaps in the miters. probably less cost aswell not having to finish the trim .
Old 08-09-2010, 09:21 AM   #8
gmhammes's Avatar
I would have the problem with pet hair and dust collecting under the gap. I still like the idea and am awaiting results!
Old 08-09-2010, 10:44 AM   #9
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Great idea. Base trim can be a pain to paint and to fit. Keeps us posted on how it turns out.
Big N8 is offline   Reply With Quote
Corner Bead Coming Loose bhumeny Drywall & Plaster 4 05-03-2010 09:33 AM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 09:20 AM
