Corner Bead An Inside Corner? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 07:14 PM   #1
HomeOwner
Rewards Points: 81
Send a message via Yahoo to Firehawk734
Corner bead an inside corner?
I have a good size gap, almost 1/2" on an inside corner. Will I still be ok paper taping the corner? I had planned to fill the corner good with mud and then paper tape it, of course getting the mud out from behind the tape.
One other idea i thought of doing to give myself a nice corner was to stick metal cornerbead in there and then feather it with mud. Would this be fine to do?
Firehawk734 is offline   Reply With Quote
Old 05-27-2011, 07:24 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Regular joint compound under paper tape will take a long time to dry under those circumstances I think. One of the local drywall finishers here will have a recommendation maybe. In the meantime, I would first fill the void with 45 minute mud. Then once that was hard tape and mud it normally.
I don't think using a metal corner bead in an inverted manner is the way to go because of the profile of the bead.
XXX
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
Firehawk734 (05-27-2011), oh'mike (05-28-2011)
Old 05-27-2011, 11:56 PM   #3
No, don't put a corner bead on an inside 90 degree corner. Simply fill the void, let it set or dry and then tape as normal.
dberladyn is offline   Reply With Quote
The Following User Says Thank You to dberladyn For This Useful Post:
Metal corner bead on 20' soffitt MikeKy55 Drywall & Plaster 4 04-12-2011 06:18 PM
Framing Support for Inside Corner on L-Shaped Stairwell jsoares4 Carpentry 5 01-24-2011 07:25 AM
Corner Bead Instead of Baseboard Molding MartinD Drywall & Plaster 8 08-09-2010 09:44 AM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
Painting Rooms with Round Corner Bead leafyme Painting 9 08-20-2008 02:52 PM
