-   -   corner bead for drywall (http://www.diychatroom.com/f101/corner-bead-drywall-42369/)
cfarmer 04-13-2009 02:46 PM
I am installing corner bead, but I can hit a wooden stud only on one side. The other side goes straight in to the drywall. I'm looking for solutions.
thanks
Gary in WA 04-13-2009 04:08 PM
Paper tape corner bead.
You may need this: http://www.google.com/url?sa=U&start...cdF20uC32HLqzw
Be safe, GBAR
bjbatlanta 04-13-2009 04:20 PM
If the corner was framed correctly (i.e. corner post and not just a stud), there would be ample nailing on both sides. You should still be able to hit the stud by angling your nails back slightly UNLESS you're adding a second layer of drywall. GBAR's recommendation for paper bead will solve your problem and actually is a better system overall. Way less problems with it "popping" loose later on down the line. I've used it for a while and would recommend it....
