Corner Bead Coming Loose - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-29-2010, 03:03 PM   #1
My house is approx. 20 years old.
Recently, the corner bead in several places has started to come loose and there is a crack along the edge of it.
I tried to repair one strip by first just mudding over it, but the crack just reappeared. I then putting in a couple of drywall screws, but the screws caused the corner bead to buckle about 2 inches away from the screw and made a bigger mess.
What is the proper way to refasten the corner bead?
P.S. I am not sure if the corner bead was the screw-on type or the type with paper but I suspect it is the screw-on type as the crack is only about one inch from the corner (not wide enough for the paper type)..
Thanks in advance.
Bill
bhumeny is offline   Reply With Quote
Old 04-29-2010, 08:16 PM   #2
DIY staff
Rewards Points: 7,174
Have you got a small crown stapler? That is the easiest method of securing the corner bead without making a mess out of it.
You will need to take a small hammer and knock any of the loose mud off of the corner bead---
the best mud for the repair is Durra Bond--That is the powdered mix in a bag--Very sticky and hard.
---Mike---
Old 04-29-2010, 11:21 PM   #3
Remodeling with Pride
You need to screw the corner bead, apply a fiberglass mesh tape to cover the cracked area, the apply Durabond joint compound.
LotzRenovations is offline   Reply With Quote
Old 04-30-2010, 07:08 AM   #4
DIY staff
I've never had much luck using screws--I always end up puckering that thin tin.
Old fashioned drywall nails seem to work just fine though.
I never paper or mesh at the corner bead--I would think that would bring the drywall mud out past the corner bead----??
Good luck-Have fun---Mike---
Old 05-03-2010, 09:33 AM   #5
Drywall contractor
Rewards Points: 1,070
Nails, then first coat with setting compound.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
corner bead , drywall
Painting Rooms with Round Corner Bead leafyme Painting 9 08-20-2008 03:52 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Corner Bead ceeking General DIY Discussions 1 06-17-2008 08:58 AM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 09:20 AM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
