Conventional Sheetrock Or Blue Board Veneer? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 08:58 PM   #1
Rewards Points: 31
Conventional sheetrock or blue board veneer?
Greetings: I am in the process of a complete home remodel with an addition. The existing portions were gutted to the studs. It is now time for wallboard and have been in touch with several contractors for advise and pricing. I have narrowed it down to a couple of contractors. One strictly hangs conventional drywall and finishes it off with a tuff-hide primer after taping. The other hangs blue board with a plaster veneer. Any input would be appreciated as to what direction to travel here. Pricing by both is comparable. Thanks.
Rustygaff is offline   Reply With Quote
Old 02-18-2012, 10:24 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
I've never used it, but sounds good. seems to be like larger sheets of the old plaster rock lath?
http://www.hometime.com/Howto/projec...ent/base_4.htm
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-21-2012, 10:55 AM   #3
Rewards Points: 31
The blueboard gypsum sheets are the same core and size as conventioinal sheetrock. The only difference I believe is the working side paper surface. It is supposed to be very porous to accept and adhere the plaster veneer skim coat.
I still haven't decided which system to go with yet. For roughly the same price, I can get a sheetrock job (hung, taped w/3 coats + USG Tough-Hide primer) vs. a blueboard plaster veneer job. I did look at one of the plaster contractors job sites. The plaster finish is real smooth. Feels like an eggshell coating over the rock.
On the other hand, I would still have to prime coat the plaster where if i went with the sheetrock contractor, the priming is done. I am looking to avoid priming and/or painting the ceilings if I do not have to.
Old 02-21-2012, 11:21 AM   #4
Rewards Points: 528
It depends. if you are in NE then I would suggest the veneer plaster, in other parts of the country, regular drywall and taping is what is "normal".
framer52 is offline   Reply With Quote
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 05:57 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
Stone veneer over foam board. rfjm58 Building & Construction 6 04-10-2007 07:40 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Blue Board georgetax General DIY Discussions 7 11-11-2005 10:05 PM
