Condo Drywall Replacement - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 03:13 PM   #1
Condo drywall replacement
Can I just replace the drywall in my condo or do I have to replace the steel framework / studs, too?
Lisa, SPB is offline   Reply With Quote
Old 02-05-2011, 03:15 PM   #2
Experienced
Jackofall1's Avatar
Do just the drywall, walls studding will remain in place.
Drywall between units must be 5/8" for a fire rating.
Mark
Old 02-05-2011, 04:25 PM   #3
Registered User
Rewards Points: 5,204
Is the drywall damaged from water? Or is it cosmetic damage from pets, children, etc.? Can you just patch it or skim coat the surface with texture for a new look/finish?
Gary
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 03:05 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
Hanging drywall Question avtck Drywall & Plaster 6 01-05-2010 07:21 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
