Condensation In Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 11:22 PM   #1
Rewards Points: 71
Question
condensation in drywall
One of the exterior walls in bedroom has moisture in drywall due to condensation..mainly at the bottom of wall...currently I have removed 4 feet height of drywall and from inside of the house, I can see water resistant sheathing behind this sheathing there is plywood and than a gap and again a plywood and than siding..
I have moisture meter...and when I check the moisture on this water resistant sheathing (currently I have removed drywall and blow in insulation material) it shows around 22% at bottom but just above 1 feet from bottom it is 16% or less...so what is the solution?
btw when I kept the windows open and door open...this bottom moisture came from 22 % to 15% or less...
One more thing this room has two exterior walls...one the front exterior wall ...no problem but on side exterior wall this problem...
I was told best solution is ventilation but in cold we can not keep windows or door open...so what is the solution?
vapor barrier or any other material that can stop meeting hot air from inside to outside cold air? or any other idea to solve this?
vikasintl is offline   Reply With Quote
Tags
condensation , drywall , moisture , sheathing , ventilation
Rookie questions - drywall paper rips Eusibius2 Drywall & Plaster 13 08-14-2010 09:46 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 06:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
