Close Off A Doorway With Drywall That Has Corner Bead. Remove Or Mud Over? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 10:07 AM   #1
Close off a doorway with drywall that has corner bead. Remove or mud over?
I have a doorway with metal corner bead. I want to close off the doorway with drywall. Do I have to remove the corner bead before adding the wall and drywall to block off the door in order to get a smooth finish?
cmgraue is offline   Reply With Quote
Old 02-01-2012, 10:10 AM   #2
Rewards Points: 12,858
If you do not want a hump the shape of the door in the middle of the wall then yes it's got to go.
I just tap it with a hammer to break up the old mud and pry it off.
Willie T (02-01-2012)
Old 02-01-2012, 12:09 PM   #3
Old School
Willie T's Avatar
This entails an awful lot of work. It might take you all of eight minutes to do both sides of the door.
Willie T
Old 02-01-2012, 01:05 PM   #4
DIY staff
Rewards Points: 7,174
Depending on the framing---it is ideal to also cut back the drywall at least 8 to 10 inches to remove the part with a layer of drywall mud.
Old 02-01-2012, 04:00 PM   #5
retired union carpenter
Send a message via Yahoo to coupe
if you want a smooth finish? yes. it's best to cut drywall back to center of next stud on both sides. and patch appropriately
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
The Following User Says Thank You to coupe For This Useful Post:
oh'mike (02-01-2012)
Drywall in a Corner with No bead mobiledynamics Drywall & Plaster 3 11-20-2011 04:25 PM
drywall arch corner bead rustic Drywall & Plaster 16 10-27-2009 05:58 PM
Butt Joints at new drywall and existing corner round VistaV Building & Construction 1 02-03-2008 10:36 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 04:25 PM
