#1 |
cinderblock, rock house..
We are remodeling our bathrooms at the moment but i have a few questions about re-running the wires in one. We planned on adding 1x2's on our cinderblock exterior walls of our house to put in drywall and allow for some insulation and change some wireing around. Is there a better way of doing this? that bathroom gets so hot in the summer and so cold in the winter.
Also that bathroom has the glass blocks for windows(2blocks wide on both sides of mirror) with little vents above them, we hate them and want to cover them up till we can fix the outside of the house and put in rock where they are. The house is over 60 years old and has only 2 prong outlets. The light above the bathroom mirror is the only light and only plug in the room. Being a woman and needing to curl, blowdry my hair is not very fun with a step stool or extension cord. Any advice would be appreciated. Thanks |
#2 |
Drywall contractor
The best bet would be to frame 2"x4" walls so you can add batt insulation and you have plenty of room for boxes, wiring, etc. That is of course IF you can spare that much room and still work in whatever type of tub and/or shower you are planning on. If you end up using the furring strips, you can use 3/4" foam board in between to give at least a bit more R value....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
#3 |
yeah the particular bathroom i'm speaking of barely has enough room for a toilet in it...heh.. as the layout was before the cabinet that sat in front of the toilet barely allowed for you to open the cabinet door all the way..
#4 |
STAFF
The bad part is if you don't insulate the outside of the block walls everything you put inside will rot from the condensation. There will be mold where it is warm, dark and damp, which is what it will be behind anything you put on the inside without first insulating the outside.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
| Display Modes | |
| replumbing an old house | simonfrog | Plumbing | 7 | 01-30-2012 05:45 AM |
| My house progress so far - over the years | Snav | Project Showcase | 3 | 04-28-2010 06:35 PM |
| Trane XR12 1.5 ton-Too small for my house? | Badfish740 | HVAC | 7 | 09-23-2009 06:48 AM |
| I have Central Heating & Air, but house won't cool down..HELP!! | exiledone1 | HVAC | 13 | 07-10-2009 11:09 PM |
| Some walls rattle in my house if hit with something, I will explain inside posting | zincmann | Building & Construction | 4 | 11-10-2008 04:05 PM |
