CFM Question For Knockdown Texture - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-02-2016, 07:13 PM   #1
Rewards Points: 4
CFM question for Knockdown Texture
I am attempting to do knockdown texture on my ceiling. The compressor I have is a Dewalt D55168. It rated at 5 CFM @ 90 psi.
The hopper gun i have is a Wal-Board Texture-Pro 200. It calls for 2.4 CFM @ 90 psi.
Can i make this work?
polg0003 is offline   Reply With Quote
Old 05-03-2016, 11:01 AM   #2
Rewards Points: 144
Re: CFM question for Knockdown Texture
The compressor is probably overated at 5 cfm and the texture gun will shoot a lot better at more than 2.4 cfm.Do not use 90 psi.
Thin the mud to get a mayonnaise like mix.Maybe a bit thinner.Add a bit of of Ivory dishwashing soap to the mud.Set your compressor to 45-50 psi and test it on a scrap or piece of cardboard .You'll have to mess with the mixing valves on the hopper to get it right.
The set up with this compressor and hopper is borderline but workable.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
polg0003 (05-03-2016)
Old 05-04-2016, 07:29 AM   #3
Rewards Points: 5,974
For knockdown I might start a little lower around 35-40
Entering your general location can help with answering a lot of times
Old 05-04-2016, 10:27 AM   #4
Rewards Points: 4
Does the CFM effect the proper PSI?
Old 05-04-2016, 01:34 PM   #5
Rewards Points: 144
Yes.But for what you are doing as far as spraying texture it's a good thing.Set the compressor at around 40-45 psi for the hopper gun and you will have more cfm than you will at 90psi.Plenty of pressure for spraying texture.
Don't do like some do and keep turning up the pressure if the gun does not work correctly.Adjust the gun or thin the mud.It takes a little practice to get things tuned properly and the correct consistency of the mud but 40-45 psi is plenty .Adjust everything else accordingly.
polg0003 (05-04-2016)
How to spray orange peel texture in a can on a drywall repair Sir MixAlot How To Guides 0 10-12-2014 04:12 PM
Texture walls - one room or all porford Interior Decorating 6 07-27-2011 03:39 PM
Applying texture on smooth cement interior walls Flt_Simulation Remodeling 8 05-14-2009 05:23 PM
popcorn texture question kenmac Building & Construction 8 02-27-2009 03:22 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 03:50 PM
