Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-27-2011, 02:35 PM   #16
Cement Board Questions
Just for anyone who is seaching for similar answers.
I, as well another fellow that I found online both independently contacted Schluter, and Schluter did not recommend to slash or cut the vapor barrier open. Apparently it should be used on all exterior walls, regardless that Kerdi is applied. So I will be keeping mine on the 5 x 8 exterior wall. Also, two of the Schluter suppliers also noted here in Ontario that vapor barrier is kept behind the cb prior to applying the Kerdi.
Thanks for all the posts though.
trophywalleye is offline   Reply With Quote
Old 06-27-2011, 03:19 PM   #17
ccarlisle's Avatar
Well, all I can say is that if you ask 10 Schluter guys about Schluter products and they'll all say the same thing; if you ask 10 tile guys about Schluter products in a tiled shower, you'll probably get a 50;50 split. If you ask about Kerdi products in a tiled Ontario shower system - if you can find 10 of those - you'll also get a mixture of answers.
The fact is debatable and it is far too early in the existence of "Kerdi showers in Ontario" to be able to say what the right way is; but one thing Kerdi won't tell you about is how we here in Canada like to have our showers dry to the interior and we use Kerdi because it is (a) waterproof and (b) a vapour retarder. If you are worried that the small amount of vapour getting passed the Kerdi, the cbu and the vapour barrier, then by all means keep the vb intact. IMO there is greater evaporation 'draw' of vapour to the inside of a 20deg C house in winter than there is tendency for that same vapour to exit via the wall cavity.
But that's just me....
ccarlisle is offline   Reply With Quote
Old 06-29-2011, 11:56 PM   #18
Moderator
When you make a hole or slit in an air-barrier on a house, it will compromise it greatly. In a vapor barrier it has almost no effect except the width/length/size of the hole/slit, the rest of it is still working, (not like a balloon when a pin-hole ruins it- more like a brick wall with a few bricks missing)
Gary
Clothes taking longer to dry?
Cement board for crawlspace skirting? IfItAintBrokeFixItAnyway Building & Construction 12 09-29-2010 08:43 PM
Cement backer board wadeseward Flooring 16 09-10-2010 12:34 PM
Laying cement board oguevarra Flooring 18 12-16-2009 10:21 AM
what waterproofing substance on cement board in bathroom(can't find Red Guard) Limit54 Building & Construction 15 11-19-2009 07:30 PM
Cement hardy board tmiles2246 Flooring 9 05-11-2009 05:10 PM
