Cement Board Painted - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 01:14 PM   #1
cement board painted
can cement board just be painted to use outdoors
pattexaco is offline   Reply With Quote
Old 09-04-2011, 01:21 PM   #2
m1951mm's Avatar
A short answer, yes you can paint cement board. Will it last is the question. Cement board is very porous and will take paint easily, will the paint stay on the surface???? Can you explain what project you have in mind for the cement board???? That way you will get a better answer to your question
After thinking about my answer it is geared towards durarock. There are cement boards that simulate siding for the exterior of a home.
What is the substrate that you are asking about????
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 09-04-2011, 02:38 PM   #3
cement board for outside use
Can I just paint cement board? I wanted to use it to close in a table that will stay under cover.
Remodeling bathroom - question regarding cement board prontocruz Building & Construction 2 06-27-2011 06:11 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
Cement Board cougar01 Flooring 2 10-29-2010 03:35 PM
Correct detail of preformed shower pan meet the cement board of a shower wall eyeglass Building & Construction 0 08-31-2010 02:31 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
