Cement Board Over Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 03:36 PM   #1
Talking
Cement board over drywall
I am renovating my 22 year old hall bath and when I tore out the tiles and board, I realized they had built the tub/shower walls by using drywall and the putting cement board over the drywall where the tiles would go. This also "built” up the wall for the tile so they were raised slightly above the rest of the wall. Is this common? Should I replace the same way or would it be better to leave the wall flat and retile without them being “raised”?
It seems somewhat unnecessary to put cement board over drywall just to have a raised look.
Spacebear3 is offline   Reply With Quote
Old 08-29-2011, 06:49 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is this common?
Yup, in Texas it is. In fact Texas is the only place I have ever done that type of thing.
It doesn't have to be done that way tho. To do it that way would require a special tile to make the bends around the cement boards and even tho that type of tile is still around there aren't very many colors or textures to chose from. It may even be a "dated" look these days. I know I haven't seen or used the stuff since I left Texas eighteen years ago.
XXX
Tags
drywal cement board bath
Assistance with tile layout / transition between cement board and drywall JeffreyMCooper Tiling, ceramics, marble 4 08-20-2011 11:47 AM
drywall compared to cement board on garage ceiling Goob Drywall & Plaster 4 04-05-2011 03:57 PM
Correct detail of preformed shower pan meet the cement board of a shower wall eyeglass Building & Construction 0 08-31-2010 02:31 PM
Drywall or studs first before self leveling cement sandoy1121 Flooring 0 07-26-2010 06:50 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 10:32 AM
