Cement Board For Concrete Wall Look. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 09:22 PM   #1
Cement board for concrete wall look.
I'm pulling down all the drywall in my warehouse as its old, was put up poorly by a previous tenant and I'd like to add a little character.
That said I was thinking to avoid doing drywall for 1200sqft of perfectly flat 20ft by 60ft of wall.. that I would just do cement board similar to this:
Does anyone have any experience doing this? I imagine there are a few tips/tricks to making it look good, or which cement board to use.
marcus22 is offline   Reply With Quote
Old 05-03-2013, 12:13 AM   #2
Hardie board smooth panel siding. But it should be sheathed first, not just put on studs.
It's about 30 bucks a sheet.
jsbuilders is offline   Reply With Quote
Old 05-03-2013, 12:23 AM   #3
Rewards Points: 744
Cement board, especially Durock, like shown in that picture has zero structural strength. It bends and flexes quite a bit, therefore, you would at least need a layer of 1/2" plywood or OSB behind it. Of course, that would bring out the wall about 1/4", after the CBU is attached to it (assuming you used 1/4" thick CBU). And then you have to figure out a way to seal the CBU panels, because they shed sand when you touch them. Keep in mind, you're going to have a lot of cement board screws to hold those panels up too, and they're green, so you may want to paint each one with a coat of gray paint, to help hide them. I don't see any screws in that picture, so it may have just been stuck on with thinset or construction adhesive. Is that picture from an advertisement? If so, it was probably just put together for a few pictures and may not actually be practical for real-world environment. It might be easier to have an artist do a faux painting, after applying a sand coat to a drywall wall.
Seattle2k is offline   Reply With Quote
Old 05-03-2013, 12:26 AM   #4
Rewards Points: 744
hardiebacker has a different look and has the screw grid formed into it..wouldn't give the same look.
On the other hand, Durock has their name printed on it...at least on one side, not sure if its on both sides.
Old 05-03-2013, 12:48 AM   #5
But that's not backer board. It's fiber cement panel siding. Actually I'm pretty sure it's certainteed not Hardie, the lines in it are pretty distinct.
Old 05-03-2013, 12:53 AM   #6
Most likely spiral shank siding nails.
Old 05-03-2013, 04:29 AM   #7
Being the wall is 60ft long by 20ft tall and has no outlets/etc on it I figured that cement board without any finishing would be the quickest and easiest way to finish the wall while still looking nice.
But if I need backer, and sealer, and special screws, or paint then sealer, etc.. then I'm just back to where I started with the painting and what not.
I'd still entertain doing it if only backer was needed.. and even sealer.. but if I have to paint and seal.. and all that I think just drywall is likely the route I'll go.
I found that picture in google images searching for "cement board loft" or something similar to that.
Old 05-03-2013, 04:31 AM   #8
What about something like this, with a backer.
http://en.gt-sgbc.com/ProductInfoExh...ist-cp004.html
Old 05-03-2013, 04:40 AM   #9
or even this: http://www.fibercementproducts.com/blog/?page_id=905
Old 05-04-2013, 12:23 AM   #10
What about galvanized barn siding. Dent it up a little to give it a nice commercial look.
A local restaurant did it, and it really looks good.
The Following User Says Thank You to jsbuilders For This Useful Post:
oh'mike (05-04-2013)
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 10:13 PM
Deck: gap from 1st deck board to wall frankkerfoot Building & Construction 2 05-16-2012 09:49 PM
Cement Board or Drywall or Both Calvo Remodeling 6 03-07-2012 12:24 PM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 11:11 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
