Ceiling Thickness - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 11:24 AM   #1
msaeger's Avatar
Rewards Points: 260
Ceiling thickness
I have 24" joists and have always heard you have to use 5/8 drywall on the ceiling but everything I read says to use 1/2 inch. So what's the truth? I would rather just use 1/2 for everything than deal with 5/8 just for the ceiling.
msaeger is offline   Reply With Quote
Old 09-08-2011, 12:33 AM   #2
I would think if you have 24'' you should probably go 5/8. You may be fine with 1/2 with 16'' centres however I would worry about sag. Out of practice I usually use 5/8 for ceilings in most cases.
Another thing to keep in mind is local codes-around here if you have another dwelling unit above you, you have to use 5/8 as a fire seperation. You should look into this (as well as fire blocking you may require) and make sure you are good and legal.
chrisBC is offline   Reply With Quote
Old 09-08-2011, 11:50 AM   #3
Registered User
Rewards Points: 526
Good points above. The drywall manufacturer recommends 1/2" on ceiling (perpendicular app. only) without a hand/machine water-based texture applied, or go to 5/8"; Table #1. Table #4 states 1/2" will only support 1.6# insulation at 24" o.c. without sag, don't use cellulose over that weight limit;http://www.energyguide.com/library/E...SubjectID=8375
http://gypsum.org/pdf/GA-216-2010.html
Gary
Old 09-08-2011, 04:49 PM   #4
You can run furring strips perpendicular to the joists at 16" OC if you would rather use 1/2"
1910NE is offline   Reply With Quote
Old 09-09-2011, 09:53 AM   #5
msaeger's Avatar
Rewards Points: 260
I already built the interior walls would that be an issue with installing furing strips? Does it make a difference if I use light weight drywall? I am planning on getting lightweight for the 1/2 inch stuff anyway. That's all they sell at the home improvement places now :-)
Old 09-09-2011, 09:31 PM   #6
When you say you have already built the interior walls, I assume you are not saying that they are already sheet rocked, but framed up...Regardless, it shouldn't matter. you will lose about 3/4" of ceiling height, but gain a much better space to work with. A Google search on furring out a ceiling will give you a bunch of information to work with.
Old 09-11-2011, 03:31 PM   #7
Drywall contractor
Rewards Points: 1,070
The new "lightweight" gypsum panels by USG (and others I'm sure) are claimed to be suitable for 24" centers WITH texture and "sag resistant". I have used the USG product personally with no problems. Check the mfgr.'s website for the products available in your area (USG, CertainTeed, Georgia-Pacific, etc.). USG states their "ultra light" panels "can be used on ceilings with 24" o.c. framing spacing when water based texture is applied". As stated above, check local codes also in case there is a fire code issue....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-11-2011, 04:10 PM   #8
Registered User
Rewards Points: 526
Thanks for that, BJ. Need to up-date my intel. OP, be sure to read the application instructions- only perpendicular to framing members...... and it is same insulation carrying abilities of 5/8" regular, 2.2# per sq.ft.
Gary
Old 09-11-2011, 04:23 PM   #9
Drywall contractor
Hey Gary, you're the "go to" man for information. I love the new lightweight rock and am glad it's actually "better" than the old regular board. I hear the 5/8" firecode is out, but have yet to see it at the big box stores. That will be HUGE for us old guys with bad backs, shoulders, etc...
Old 09-11-2011, 09:45 PM   #10
msaeger's Avatar
Rewards Points: 260
So I the celing joists are the collar ties which are 2x8. I am planning on putting R19 or R21 in between the joists and some more fiberglass on top perpendicular to the joists.
So will the 1/2 inch light weight be ok? I keep seeing it should be but talking to people they say I should use 5/8. I don't know if it's just them giving me old information or if the 1/2 lightweight really can't handle it.
Old 09-11-2011, 10:56 PM   #11
Registered User
Rewards Points: 526
It has a inner fibers for strength, stronger than 5/8" regular. It will be fine; http://www.americangypsum.com/data/p...alsheet541.pdf Also handles 2.2lbs. of insulation, same as 5/8". Hah, now I'm repeating myself...... They say as you get older the first thing to go is your memory, I can't remember the rest.....
Must have been the lite-roc that has the fibers..... I will stop now, two for two.....
Gary
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Need help in finding 3" recessed light housing for 1 1/8" inch ceiling thickness mystiky Electrical 5 07-09-2011 10:42 AM
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 03:37 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
