Ceiling In Shower Stall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 03:57 PM   #1
Ceiling in Shower Stall
Hi,
I've gutted out my bathroom shower and am ready to put cement board up on the walls. My question is should I put cement board on the ceiling or just use green-board. I plan on not tiling the ceiling--just painting it.
I was told Red Guard waterproof membrane is what should be spread on cementboard walls after seaming and mudding the joints...others have said to use Mapei AquaDefense. I found RedGuard at Home Depot..couldn't find AquaDefense anywhere locally to Sweetwater, TN.
Any comments as to whether I am on the right track or not would be appreciated.
Thanks,
Murph
Murp-the-Surf is offline   Reply With Quote
Old 10-26-2011, 04:18 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Everyone has their own preference of liquid waterproofing. Redgard is fine. May not be the best in someones opinion but it is accessible to you and it works fine.
The Following User Says Thank You to Bud Cline For This Useful Post:
Murp-the-Surf (10-26-2011)
Old 10-26-2011, 04:47 PM   #3
Cement Board on Ceiling??
Bud, Do you think I should use Cement Board on the ceiling or blue/green board?
Old 10-26-2011, 08:26 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I wouldn't use cement board, it's just to stinkin' hard to bring back to a suitable surface even for texturing. I also think Redgard would screw things up for painting. You would be better off using a quality oil-based paint or whatever replaces oil-based paint these days. Is that alkyd?
Murp-the-Surf (10-27-2011)
Old 10-27-2011, 05:33 PM   #5
Another Quick Question
Bud,
I read somewhere that when you build up the mud for a shower pan you can use a product that has a bunch of rails that you lay on the floor to keep the slope consistent. I guess you cut them and snap them into place so when you put down your mud all you have to do is bring the mud up even with the rails. You then seal it with a Redguard type product and oput your rubber shower pan material down over that and then tile.
Am I missing something and are the rails the way to go??
Murph
Old 10-27-2011, 09:20 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That is the "Quick Pitch System". You do not use Redgard with this type of system. You would use a vinyl shower pan. You can get the system here:
https://www.tiletools.com/product/ma...rd-kit-356.cfm
The problem with using a system like that one is it ignores the Tile Associations recommendation to first install a pre-sloped primary base to direct the shower pan liner. That system gets installed on a flat pan liner and I would strongly advise against that.
A much better way to go is the Schluter System's Shower Kit. Absolutely everything you need to construct a state-of-the-art-shower is in this kit. I have been using this system for several years.
https://www.tile-experts.com/products.asp?id=53
This system involves no concrete, only thinset mortar. It includes a special vinyl pan liner material (KERDI) that installs on top of the systems components. The kit includes enough vinyl product to also water proof the walls. The curb form is included along with a special first class drain.
Tags
shower tile , tile
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
framing a shower stall n2learning Building & Construction 10 04-07-2011 08:34 AM
Shower stall installation mforeman1 Flooring 1 04-06-2011 08:39 AM
Handicapped shower stall reelwood Plumbing 5 10-28-2009 01:35 PM
How to build base for a shower stall atm Plumbing 13 05-13-2009 11:18 AM
