Ceiling Sheetrock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 07:58 PM   #1
Rewards Points: 1,584
Ceiling sheetrock
I need to remove all the ceiling sheetrock (moisture damaged, roof leak, mold, cave in) and put up new sheet rock and new insulation. All 3000 SF of it.
Is ceiling sheetrock typically estimated as a $/SF, or is it a case by case depending on how many high hat lights cut outs, how many odd shaped soffit boxes etc...?
Is it better to hire out the whole project or is it better to break it into stages and use different people for each?
- Demolition (remove old sheet rock, old insulation, remove fasteners, dumpster rental, haul away, disposal).
- New sheet rock install, patch and sand.
- New insulation in attic.
- Paint new ceiling.
miamicuse is offline   Reply With Quote
Old 02-07-2013, 07:55 PM   #2
Rewards Points: 512
not going through insurance???
none of the walls got damaged?? if it was leaking that bad with mold im sure atleast some of your exterior walls will be affected with wet insulation.
i recommend hiring a restoration company, they deal with jobs like this on a daily basis with the know how for mold removal and making sure your place is properly dried out.
princelake is offline   Reply With Quote
Old 02-07-2013, 08:06 PM   #3
Rewards Points: 5,974
In my opinion your sheetrock guys will probably do the demo, but you also need insulation guys, and painters. For something this size all in one seldom works. And where I am sheetrock work is usually bid by the sq. ft. then add on for something unusual.
Trying to connect 2 ceiling fans to 1 switch alberta86 Electrical 6 02-05-2013 06:08 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Textured ceiling Sheetrock repair theatretch85 Building & Construction 10 02-25-2009 06:14 PM
