Ceiling Seams All Cracked! - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-19-2013, 01:52 PM   #16
Rewards Points: 626
Originally Posted by ToolSeeker View Post
Sorry bags but there is a 3rd option. Fix it right!
Yes your right. for him doing a complete sanding off of the mud down to paper then re doing the tape and mud and his skill levels might be basic? my suggestions are based on skill level and time and money. are either to skim coat the whole ceiling or shoot it with texture and do a knock down the latter is entry skill level the first is high skill level. Which one based on skill level would you suggest to a novice? I think my suggestion will work. The real issue is education of people to the hazards of mesh tape.
Nailbags is offline   Reply With Quote
Old 08-19-2013, 06:06 PM   #17
Rewards Points: 5,974
Here is what my reply is based on-he said he had experience with dry wall and taping. If he removes the tape a lot of the old mud will come with it. Then if he gets the roughest sanding screen he can find the rest will sand pretty easy. Then when he tapes and muds all he needs is thin coats and feather them out. I have found heavy texture especially ceilings to be very messy and not really an easy job. But about the mesh tape I totally agree, it should be illegal to even sell that crap.
Old 08-20-2013, 08:00 AM   #18
PoleCat's Avatar
Rewards Points: 1,646
When we bought this house 20 years ago there were some seam cracks in the addition ceiling. I ran paper and regular mud along those and "thought" I had them feathered in. When the light hits it right you can see the bulge but the cracks never reappeared. I used several roles of mesh over the years that did not crack right away like these have. My blissful ignorance has been shattered. I have gotten much better at feathering out a joint since then so it looks like another bucket of mud and some paper is in order. I bought a hopper gun and knock down knife a few years back but haven't had the opportunity to use either. Now I find myself apprehensive about ing it all up with that! Good thing I take medication for anxiety.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following 2 Users Say Thank You to PoleCat For This Useful Post:
Nailbags (08-21-2013), oh'mike (08-20-2013)
Old 08-20-2013, 08:30 AM   #19
Pole that is the problem with mesh tape you can use it and as long as nothing ever moves it will last. But the slightest movement will cause cracking. And I really mean slight movement. Take a piece of mesh tape and hold opposing corners now very gently pull in opposite directions and you will see why it can't take movement.
Old 08-20-2013, 08:49 AM   #20
PoleCat's Avatar
Well I've been schooled. All my remaining mesh went to the dump.
The Following User Says Thank You to PoleCat For This Useful Post:
Old 08-20-2013, 11:13 AM   #21
Rewards Points: 4,784
If mesh were made of an absorbent material rather than plastic, and the fibers were larger and the holes smaller, it might work. It would be nice if they could invent something that had the strength of paper and the convenience of mesh to apply.
jeffnc is online now   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 08-21-2013, 04:21 PM   #22
automated tool pro
Rewards Points: 152
hang a 2nd layer
drywallfinisher is offline   Reply With Quote
Old 08-21-2013, 04:29 PM   #23
Originally Posted by drywallfinisher View Post
hang a 2nd layer
That's pretty extreme for just a seam that cracked, don't you think.
Old 08-22-2013, 10:06 AM   #24
PoleCat's Avatar
I have seen paper with holes peppered all through it. Never investigated what it was for though....too busy grabbing the mesh that was next to it.
Old 08-22-2013, 10:20 AM   #25
I think that would probably be paper corner bead. Not really sure why it's designed that way.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Another 2x6 cathedral ceiling juststarted Building & Construction 17 11-22-2011 05:27 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
