Ceiling Seams - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 09:53 PM   #1
Rewards Points: 131
Ceiling seams
The previous homeowner nailed 3 inch wide floor boards to the ceiling in the entire house. I took the boards down from the bathroom ceiling. The boards are nailed at every joist. So, I had to do repairs every 16 inches. I managed to do a great job in the bathroom and I only have a few spots in my seams/repairs that are slightly noticeable.
Having achieved the task in the bathroom, I tried to do the same job in the much larger kitchen. Unfortunately, I just primed the ceiling and it looks like crap. Most of the 'seams' created to repair the nail holes are visible to varying degrees. After priming, I checked the seams with a 12inch knife and they are humped...I sanded with a sanding sponge and was constantly checking the seams with my hand and i thought they were flat but obviously not. Now, given that seams are only 16 apart, what can I do? I know the seams need to be fanned out wider, but since they are not that far apart will it be worth the effort? I feel like I did the same thing in the kitchen as the bathroom but the result in the kitchen is horrible.
The choices I made were based on not having a helper to hang new boards, the only drywaller within 2 hours is very busy but also not the most reliable, I was confident from doing a good job in the bathroom.
And, I just measured a couple of the visible seams and they are approximately 6.5-7inches wide so pretty narrow.
wwkayaker is offline   Reply With Quote
Old 02-16-2013, 10:19 PM   #2
Rewards Points: 13,764
It would be great if you could post a picture so we can wee what your seeing.
Most likly just not enough sanding and the seam was not covered out far enough.
6" is not wide enough, that just bearly wider then the tape.
Old 02-16-2013, 11:21 PM   #3
Rewards Points: 131
In the ceiling, there are, I think, 5 regular seams with tape. The rest of the seams don't have tape as I simply cut out the damaged drywall and filled with mud. Due to the amount of holes along each joist, I essentially ran mud along the entire length of each joist.
Old 10-23-2014, 09:15 PM   #4
Rewards Points: 131
I am finally ready to have this ceiling textured. The ceiling seams still bother me and I have an urge to rip the drywall down and put up new sheets. I am having a knockdown texture down on this ceiling but am concerned that the seams will show. Will knockdown conceal the seams?
Old 10-23-2014, 09:44 PM   #5
Gymschu's Avatar
Rewards Points: 854
As Joe stated, you need to feather those seams out more to get rid of the hump. Texture hides a lot of things but those humps will telegraph through the texture. Most people won't notice but you will know they are there since you did the work. No need to rip down the drywall, just finish those joints properly before texturing.
Giving us your general location helps us better help you!
Gymschu is online now   Reply With Quote
Old 10-23-2014, 10:24 PM   #6
Rewards Points: 131
Since there is a seam every 16 inches, do I have really have the room to widen the seams enough to get rid of the humps? (Not being negative just wondering). In my mind, I will be covering the entire ceiling to get rid of these humps.
Old 10-23-2014, 10:38 PM   #7
Gymschu's Avatar
Rewards Points: 854
Well with a hump you will need to level those humps out with mud on each side of them. Use your drywall blade as a straight edge to see exactly where some "fill" is needed and run at least 6 inches of mud on the sides of the humps. You don't want to put any more mud on the high spots as this will only make each hump bigger.
The Following User Says Thank You to Gymschu For This Useful Post:
wwkayaker (10-23-2014)
Old 10-23-2014, 10:42 PM   #8
Rewards Points: 131
I will give it a shot tomorrow.
Old 10-24-2014, 09:53 PM   #9
Rewards Points: 5,974
Yes they will show and the ones you didn't tape will over time probably crack.
Old 10-25-2014, 12:19 PM   #10
Rewards Points: 131
Yeah, I figure they will crack too. I am ripping it out and starting from scratch like I should have in the first place.
The Following User Says Thank You to wwkayaker For This Useful Post:
ToolSeeker (10-27-2014)
ceiling seams very noticeable (new construction) danreg99 Drywall & Plaster 22 03-12-2015 07:40 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
