Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-20-2012, 10:04 PM   #1
Ceiling Repair help
Hello,
I just damaged about a 4"x4" area on my ceiling. See the picture for the details. How do I go about fixing something like this? Thank you for your help.
drew15a is offline   Reply With Quote
Old 02-20-2012, 10:22 PM   #2
Ceiling Repair help
What is it? Looks like plaster over sheetrock.
Old 02-20-2012, 10:39 PM   #3
Ceiling Repair help
Looks like standard vintage finish and bed coats of plaster. As far as a fix you can use standard joint compound (sold in buckets for ~$12); or durabond (sold in bags for ~$8) or structolite (sold in bags ~$15 but not a good option for you). You can also buy a small pail of joint compound for around $7. This would be your easiest option. If you don't own a 4" or 6" taping blade you'll also need to buy that.
However, the darkened color of the inner plaster and the rust stain (presumably around a nail) indicates a water leak problem. You should investigate that prior to any repair.
MarkusAIC is offline   Reply With Quote
Old 02-20-2012, 10:47 PM   #4
Ceiling Repair help
The hard part will be trying to match that texture. Nearly impossivle to get a perfect match. Unless you can get the person that did it in the first place to show you how they did it. There's about 100 differant ways to apply texture.
Most often the whole ceiling has to be retextured to get a perfect match.
Old 02-21-2012, 07:27 AM   #5
Ceiling Repair help
Thank you for the help.
Ceiling crack repair danzik17 Drywall & Plaster 11 10-17-2011 08:12 PM
Tray ceiling crack repair MShomeowner General Discussion 0 01-24-2011 12:43 PM
Ceiling Joist Repair Schoenly Roofing 14 01-14-2011 07:23 PM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
Ceiling Leak Stain Repair Help Please ltkenbo General Discussion 2 09-13-2009 07:38 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
