Ceiling Repair Drywall Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-07-2014, 12:29 AM   #1
Rewards Points: 372
Question
Ceiling repair drywall question
I need to rout a 1/2" wide groove for about 8' in my ceiling to properly wire and position a security camera. There is no access at from above as there is concrete ceiling above the drywall.
How do you recommend I cut the groove? What tool would you use to make the cut? Should I use two straight cuts joining to make a 45 degree angle, or a single long curved cut?
What procedure and materials would you recommend to then repair this long 1/2" wide cut?
imautoparts is offline   Reply With Quote
Drywall Ceiling Patch Repair Butt Joint and Size of Repair Area bettyRubble Drywall & Plaster 4 10-21-2013 12:26 PM
Newb DIY'er -basement drop ceiling question mike dub Remodeling 3 02-18-2013 08:37 AM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Drywall Corner and Ceiling Skim Coat Rbchound Drywall & Plaster 6 04-29-2010 11:59 AM
Ceiling Drywall - Question nthomp16 Remodeling 3 03-03-2008 01:01 PM
