Ceiling Repair - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 05:38 PM   #1
Rewards Points: 528
ceiling repair
I have a popcorn ceiling and had to do some repair.what's the best technique to use for a small area as to applying a matching finish..its a 3 by 2ft area
hidden1 is offline   Reply With Quote
Old 10-24-2013, 05:42 PM   #2
Rewards Points: 13,968
Good luck, one of the may draw backs of any texture surface.
Got some pictures?
More often then not you end up having to redo the whole ceiling to get it to match.
Or just removing it all.
Nailbags (10-24-2013)
Old 10-24-2013, 09:11 PM   #3
Rewards Points: 5,976
Popcorn is one texture where the rattle cans won't work. It can be repaired but you will need a hopper, gun, and air compressor to do it. If not a big room it's pretty easy to remove, messy but pretty easy.
ToolSeeker is online now   Reply With Quote
Old 10-26-2013, 12:26 PM   #4
Rewards Points: 528
Thanks.It is in a hallway that contiues on to many rooms.
Another area is in bathroom but isn't missing popcorn so bad.I guess in bath I can use a split roller an try to cover up the crack it had with a few loose pieces..or last resort remove it all.
With hallway I'm not as lucky..i know it won't match perfectly but do any of those spray on ones really hold up,even if u paint over it all later?
Old 10-26-2013, 03:02 PM   #5
Do you and favor and get rid of all of it.
As a home owner I can not see one advantage of texture.
As a builder it's a cheap fast way to cover up all the mistakes.
What do I need to paint and repair walls and ceiling drywall? mzaslavsky Painting 15 03-11-2013 10:06 PM
Ceiling crack repair danzik17 Drywall & Plaster 11 10-17-2011 07:12 PM
Tray ceiling crack repair MShomeowner General DIY Discussions 0 01-24-2011 11:43 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
Ceiling Leak Stain Repair Help Please ltkenbo General DIY Discussions 2 09-13-2009 06:38 PM
