Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-26-2013, 04:31 PM   #1
416
Ceiling Repair
Hello.
We had a re-occuring leak around our chimney that I think is finally sorted out. Obviously, I didn't want to fix the ceiling until I knew the leak had been fixed. This photo is of my ceiling...it appears that it's a paper covering that's peeled off.
The house is approx. 75 years old, so I'm not sure what this is or how to repair it.
Any idea's would be much appreciated.
416 is offline   Reply With Quote
Old 02-26-2013, 09:03 PM   #2
Ceiling Repair
your going to have to tear until there is no more damage
square up your tear out.
fix any surprises you've uncovered(electrical, plumbing, etc)
measure the thickness buy drywall and shim to get it smooth with the exisiting
tape and skim
sand and paint
princelake is offline   Reply With Quote
Old 02-26-2013, 10:00 PM   #3
Ceiling Repair
It looks like just paint peeling and some of the drywall paper came off. Once your sure no more leak prime with Gardz skim coat affected area with ultra lite joint compound, sand, prime, and paint. Oh and I almost forgot scrap off all the loose paint, and you will probably need to paint the whole ceiling.
Old 02-27-2013, 04:46 AM   #4
paper hanger and painter
chrisn's Avatar
Ceiling Repair
That is wall paper up there, It needs to come off. I do not know why it is red though
Old 02-27-2013, 08:02 AM   #5
Ceiling Repair
I think it's red because of a leak and it stained.
Old 02-27-2013, 08:13 PM   #6
416
Ceiling Repair
It's definitely some kind of paper. I can see seams over the whole ceiling.
It also looks as old as the ceiling...did people used to paper the ceilings for some reason? The house is about 75 years old.
Old 02-27-2013, 10:28 PM   #7
416
Ceiling Repair
Here's another room. It seems that someone, at some point (possibly at the beginning of the house) papered the walls and ceiling.
Anyone know if this was common. I sure makes things a pain in the ass now...
Old 02-28-2013, 10:11 AM   #8
MikeKy55's Avatar
Ceiling Repair
Wallpaper on ceilings was a common practice in my area. I can remember seeing done as late as the early 60's.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
Ceiling crack repair danzik17 Drywall & Plaster 11 10-17-2011 08:12 PM
Tray ceiling crack repair MShomeowner General Discussion 0 01-24-2011 12:43 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
Ceiling Leak Stain Repair Help Please ltkenbo General Discussion 2 09-13-2009 07:38 PM
