Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-12-2011, 02:30 PM   #1
Ceiling register screw broke the drywall
I have a ceiling register/grille that is secured by a screw on each end, just screwed into the drywall ceiling. On one end, the drywall has broken, with a chunk between the screw hole and the edge missing.
For now, I removed the grille. What are my options for getting it back in place or a replacement?
Thanks!
maxxjr is offline   Reply With Quote
Old 06-12-2011, 02:43 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
Can we get a photo of the area please? There may be a few different ways to approach this.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-12-2011, 03:37 PM   #3
Easy Fix.
Get a piece of tin, 18 to 24 guage and screw it to the backside of the drywall, tape and mud the broken drywall area, paint and reinstall your heat vent.
dberladyn is offline   Reply With Quote
Old 06-12-2011, 03:51 PM   #4
MikeKy55's Avatar
Another option would be to bend a piece of 10 to 24 GA metal 90º and screw it to the side of the duct inside and then run your screw into the metal. IF the hole is broken toward the opening for the register, the chipped piece won't show once it's back in place.
MikeKy55 is offline   Reply With Quote
Old 06-12-2011, 03:59 PM   #5
the Musigician
orrrrrr.... glue a piece of thin wood above it with PL adhesive, then screw it back on the next day after the glue has set.
or even sooner if you use 5 minute epoxy.
DM
Drywall or Drop Ceiling HooKooDooKu Drywall & Plaster 19 12-21-2010 01:39 PM
How to attach ceiling register to duct? adrianm HVAC 6 03-25-2010 08:29 AM
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 03:05 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 06:26 AM
