Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-20-2011, 10:29 PM   #1
I have gas!
Clutchcargo's Avatar
Ceiling - orientation of drywall
I'll be adding strapping to the ceiling joists.
Given that the strapping will be perpendicular to the joists, does it matter which direction the drywall is hung on the ceiling?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-20-2011, 10:51 PM   #2
Moderator
Yes, on the thickness of the board and if having a water based texture applied for the spans, Table 2, I think......? Read the footnotes too; http://gypsum.org/pdf/GA-216-2010.html
Gary
Clothes taking longer to dry?
Old 01-20-2011, 10:55 PM   #3
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Why are you adding strapping to the joists?
Andy.
AndyGump is offline   Reply With Quote
Old 01-21-2011, 07:32 AM   #4
perpendicular to the strapping. The strapping is the new joist..
williamwiens is offline   Reply With Quote
Old 01-21-2011, 09:11 AM   #5
I have gas!
I'm replacing the strapping what was there before. Also it makes running wires through the ceiling easier.
Is strapping not normal practice?
Old 01-21-2011, 12:47 PM   #6
Personally I have never used strapping, in my life time(35 years experience Professionally)except for channel. There is no need to fur your joist unless it is to help hide pipes or other intrusions into the plane of the drywall ceiling. If you do fur or channel you will still need to go perpendicular to the those members. It may help with sound, but then that is what channel is for.
redmanblackdog is offline   Reply With Quote
Old 01-22-2011, 03:18 PM   #7
Drywall contractor
I'd hang directly to the joists unless the strapping is to get around pipes, gas line, etc. Why was the strapping there to begin with?? What type of ceiling was it?
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
drywall basement ceiling Dgggless Drywall & Plaster 3 11-14-2010 10:43 PM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
