Ceiling Edges - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-24-2010, 03:34 AM   #1
Rewards Points: 53
Ceiling Edges
i will be hanging a new ceiling once i install ceiling joists. i plan to insulate and hang drywall as the new ceiling. so basically it'll be the 'wall first', then ceiling. i know when hanging drywall, that you usually do the ceiling before the walls, but i wont be tearing down, and replacing the walls.
i will be installing corwn molding after. do i need to worry about taping the edges of the new drywalled ceiling onto the walls?
altc81 is offline   Reply With Quote
Old 04-24-2010, 03:18 PM   #2
You do not need to "worry" about ceiling to wall tape joint as you plan to
install crown molding.. but a bedded tape joint is good practice at that location to avoid air flow and draft possibilities. It also adds a bit of stability to ceiling drywall where it might not be on a full nail-er.
PS
It also is good practice for fire protection...
Big Bob is offline   Reply With Quote
Old 04-24-2010, 06:58 PM   #3
Registered User
Rewards Points: 5,204
I agree with Bob, AND it's one of those local answers..... depends on your Building Department requiring fire-taping in the garage- paneling (1/4" minimum) required in living spaces- no draft areas between ceiling and walls (for fire travel in case any backing is missing). It's required around here, maybe there? Only your Inspector knows for sure.
Be safe, Gary
Old 05-03-2010, 09:36 AM   #4
Drywall contractor
Rewards Points: 1,070
I always at least tape the angles.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-06-2010, 09:26 PM   #5
Rewards Points: 53
it should be perfectly fine to tape the corners of the drywall(ceiling) onto the existing plaster(walls)?
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
