Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-18-2008, 05:23 PM   #1
Wounded Mathematician
shtoink's Avatar
Ceiling drywall thickness
Hi
I will soon be putting up drywall on ceilings in a 100 year old house. The ceiling joists are 24" o.c. I have heard that I should probably use 5/8" thick drywall (as opposed to 1/2") in order to prevent sagging. Is sagging something I should worry about or can I get away with using 1/2"?
Also, I have heard about a type of drywall called CD board (Controlled Density?) If anyone knows about this stuff and whether it would be suitable for ceilings, I would appreciate any advice. I have heard that it is lighter and easier to hang on ceilings.
The poets have been mysteriously silent on the subject of cheese.
G.K. Chesterton
shtoink is offline   Reply With Quote
Old 12-18-2008, 05:33 PM   #2
the Musigician
DangerMouse's Avatar
i used 5/8" fire-x on my dining room addition, and with my handy-dandy homemade drywall lift, it went right up no problem. =o)
they make special 1/2" for ceilings too. i finally posted 'plans' for the lift here if interested.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 12-18-2008, 05:39 PM   #3
DM while I was searching for your post can you build your own drywall lift?....done!, you came and went, well anyway, I was going to suggest the 5/8, in my area its like 1.40 a sheet more then the half inch, yes its heavier to lift but I figured with your innovative idea it would be alright.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 12-18-2008, 06:39 PM   #4
the Musigician
i have to pop on and off.... limited time dialup crap.....
DM
Old 12-19-2008, 12:30 AM   #5
General Contractor
Although 1/2" is acceptable per code in my area, I would go with the 5/8 drywall.
I have seen a few instances of 1/2" over 24" centers with a slight sag between the rafters.
jensenconstruction is offline   Reply With Quote
Old 12-19-2008, 11:02 AM   #6
shtoink's Avatar
According to local code, 1/2" is acceptable here, but after reading the replies here and doing some research, I will use 5/8" on the ceilings.
I may use CD (Controlled Density) board, since apparently it is lighter and easier to hang. For some of the rooms, it will make more sense for me to use 4' x 10' sheets on the ceilings (less cutting and less taping).
Is there anything I need to know about CD board? I know that compared to standard drywall of the same thickness, it is lighter, but was wondering if there was anything else different about it.
G.K. Chesterton
Old 12-19-2008, 11:50 AM   #7
the Musigician
they make 1/2" for ceilings that is 'stiffer' so you avoid sagging. but ya gotta ask them for it specifically.
DM
Old 12-19-2008, 06:55 PM   #8
Drywall contractor
1/2" WILL sag on 24" centers, especially if moisture and extra weight are introduced by texturing; especially if humidity becomes a factor (leaving windows opened in rainy weather). There is a 1/2" "sag-resistant" drywall available (USG.com). You will not find it at the big box stores and it will cost more than regular 1/2" and likely more than 5/8". Contact a drywall supply company for pricing. That said, it may be simpler to just use the 5/8". Or you could "strap" the ceiling with 1"x's on 16" centers to use 1/2" regular. You will likely have to cut every bottom wall sheet if you go that route........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-19-2008, 08:23 PM   #9
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by bjbatlanta View Post
....Or you could "strap" the ceiling with 1"x's on 16" centers to use 1/2" regular. You will likely have to cut every bottom wall sheet if you go that route........
That would be my suggestion as well. Tho, you could go with the 5/8" since the 16" OC strapping will still be spanning 24".
- Build Well -
Old 01-01-2009, 06:43 PM   #10
Strap it at 16 centers and STILL use 5/8's.
kgphoto is offline   Reply With Quote
Old 01-01-2009, 07:04 PM   #11
Why do that?
jerryh3 is offline   Reply With Quote
Old 01-01-2009, 08:05 PM   #12
Better flatter install.
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Drywall thickness for ceiling? bigbavarian Drywall & Plaster 8 07-20-2008 04:25 PM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
