Ceiling Drywall Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-17-2008, 10:41 AM   #1
the Musigician
DangerMouse's Avatar
Question
ceiling drywall question
is standard 5/8" drywall ok to use on a ceiling with 2' on center joists? the place that delivers here free only has 1/2" "ceiling" drywall, not 5/8", though the guy assures me it's standard practice to use it (standard 5/8") on 2' spans on ceilings. anyone?
DM
Old 10-17-2008, 10:49 AM   #2
RippySkippy's Avatar
Around here everyone uses either 5/8" or high strength 1/2" on 24" centers
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-17-2008, 11:55 AM   #3
the Musigician
no sag with the 1/2" then? butbutbut, in another thread they said.... owell. cool. easier for my boy and i to lift then. =o)
tnkx!
DM
Old 10-17-2008, 01:14 PM   #4
Drywall contractor
Rewards Points: 1,070
I think Rippy was referring to a specialty product. "High strength" 1/2" is not the same as regular 1/2" drywall. It is manufactured specially to resist sagging on 24" centers. USG "Sheetrock Brand", Sag Resistant drywall is an example. The core of the board is formulated to resist sagging as well as 5/8" board, but is lighter. Especially important if you are going to use a spray texture and/or are in a humid enviornment. Only available at a drywall supply. Use 1/2" regular and you will likely end up with problems. You could "strap" the ceiling with 1"x4"s on 16" centers and use 1/2" regular, but really won't be a savings. Cost of material and labor to install strapping, then have to cut 3/4" off of every bottom sheet on the wall................I'd spring for 5/8" delivered.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-17-2008, 01:20 PM   #5
BJB is right...it is NOT standard 1/2" Around here most of the home centers have it...not all though.
So what did you decide on for a drywall lift method?
LMASD
Old 10-17-2008, 01:32 PM   #6
the Musigician
reread first post. i know there's a difference. my place just doesn't carry 5/8" CEILING sheets, just 1/2". but if stiffer sheets in 1/2" is good on 2' centers, ok. as to how, read last post i did in that thread. and thankx again all.
DM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Ceiling Drywall - Question nthomp16 Remodeling 3 03-03-2008 12:01 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
