Ceiling Drywall Or Ceiling Tile. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-10-2014, 08:15 AM   #1
Rewards Points: 14
Ceiling drywall or ceiling tile.
I have a lot of HVAC ductwork to work around in my basements. So I am debating if I should drywall the or use ceiling tiles.
Ktully1973 is offline   Reply With Quote
Old 04-10-2014, 08:21 AM   #2
Rewards Points: 12,792
With a suspended ceiling it would be simple to make any plumbing, electrical, HVAC, ECT. repairs of changes.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
DIYRemodeler (04-11-2014), ToolSeeker (04-10-2014)
Old 04-10-2014, 08:46 AM   #3
Rewards Points: 5,974
I always suggest suspended in basements for the reasons mentioned. And I agree they aren't as good looking. But use your imagination, paint the metal runners a contrasting color, paint a design on adjoining tiles, cut a thin piece of shiny metal and put random so they look like mirrors. You get the idea.
Old 04-11-2014, 08:14 AM   #4
I agree. And actually, some of the products Armstrong is putting out these days look very good!
DIYRemodeler is offline   Reply With Quote
The Following User Says Thank You to DIYRemodeler For This Useful Post:
ToolSeeker (04-11-2014)
Old 04-11-2014, 03:22 PM   #5
Rewards Points: 14
I have a 7' ceiling height in my basement. Since I am going to be using ceiling tiles what is the lowest clearance that I need. I am 6'5 so I would like to keep the height as high as possible.
Old 04-16-2014, 06:34 PM   #6
retired union carpenter
Send a message via Yahoo to coupe
you can get 2x2 tiles in 2 1/2" clearence from cieling joists
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 04-23-2014, 11:26 AM   #7
Awesome, I had the same question.
ekfurs is offline   Reply With Quote
Drywall doesn't line up on ceiling thebrandnewguy Building & Construction 6 09-14-2011 08:23 AM
How would I replace ceiling tiles with drywall on a ceiling with no studs? weedelf Drywall & Plaster 3 03-01-2011 12:43 AM
Installing Drywall Ceiling daytrepper Drywall & Plaster 10 02-10-2011 01:52 AM
Removing Tile / Reusing Drywall daviswhite Drywall & Plaster 4 03-23-2010 12:36 PM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 01:24 AM
