Ceiling Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 02:19 PM   #1
Ceiling Drywall
I repaired a leak in my roof after I saw a drywall stain.
Since then, the stain has not gotten larger but the paint peeled , and the stain changed in color.
My question is - is this an indication that the leak isn't repaired, or rather that the chemical reactions in the drywall are ongoing after the leak is repaired.
Rhoba is offline   Reply With Quote
Old 02-10-2011, 03:00 PM   #2
Experienced
Jackofall1's Avatar
As the drywall dries it will change color to a rusty kinda look, to paint over this, you will need something like Kilz in a spray can, prior to coating with the matching color.
Mark
Old 02-11-2011, 03:59 PM   #3
Drywall contractor
Rewards Points: 1,070
Kikz makes a can called "Upshot" just for ceilings. You will probably need to give a skim coat (or 2) of mud after priming to fill the "void" where the paint peeled.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 09:50 AM
Installing Drywall Ceiling daytrepper Drywall & Plaster 10 02-10-2011 12:52 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-07-2008 11:05 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
