Originally Posted by moosejohnson
Hello, just begining the drywall phase in my bathroom. Starting with the ceiling, I have 16" OC joists and was wondering if 5/8 Green Board was overkill, or can I get away with 1/2 knowing I have 16" OC and a less chance for sag? Also, what screw length should I be using?
Thanks for your Help!
Moisture Resistant Sheetrock (AKA - Green Board & MR Board -around since the 70's), is slowly being phased out. It is being replaced by sheetrock that is also Mold and Mildew resistant, not just moisture Resistant.
http://www.usg.com/navigate.do?resou...sum_Panels.htm
As far as what should be used on the ceiling; Manufactures of the older green board used to require 12" O.C. fastening for 1/2" GWB ceiling applications. However, with the new material, this is not required. 16" OC is fine.
Example - Gold Bond XP Board Installation Instruction with fastening table:
http://files.buildsite.com/dbderived...ived281511.pdf
1/2" GWB should suffice, dependant on your regional standards. 1/2" Will not sag with 16" OC framing.
Use 1 1/4" Course Thread (for wood) drywall screws. (Fine thread is for steel framing).
If you plan on using actual green board, the spacing should be 1/2" OC for ceilings applications.
