Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 02:00 PM   #1
Ceiling
Hi, I just put drywall on my 20x11 garage ceiling. The joists are 24 inch on center and I add some 1x2's perpendicular to the joists at 8 ft. everything looked good so I taped and spackled. I used joint compound and fiberglass tape. After about a week the seems that are perpendicular to joist have all cracked. I was reading that the fiberglass tape can do that. Any opinions?
Also, how can I repair this?
Mud over the crack the way it is?
Pull old tape out and retape with paper tape????
Any ideas????
Thanks,
Tom
Tomperro is offline   Reply With Quote
Old 10-02-2011, 02:07 PM   #2
Rewards Points: 150
If you are able to pull the old tape out do that. If not paper tape over the cracks. You should of hung 5/8 with two foot span.
OhioHomeDoctor is offline   Reply With Quote
Old 10-02-2011, 02:09 PM   #3
I believe I used only 1/4 inch is that bad?
Old 10-02-2011, 02:12 PM   #4
Rewards Points: 150
Yes. 1/4 is not rated for walls or ceilings. Its only for laminating. This being said either tear out and block properly or laminate the ceiling with 5/8. Make sure you use right length screws. Best wishes.
Old 10-02-2011, 02:13 PM   #5
I'm sorry, but what do you mean by laminate?
Old 10-02-2011, 04:02 PM   #6
Old School
Willie T's Avatar
He means that you only use 1/4" for simply layering (laminating) right over original wall surfaces....... or in this case, leave the 1/4" up there and install 5/8" ceiling rated board over it, screwing it in well.
Tearing out the 1/4" is best because otherwise the 5/8" will have to support the possibly sagging 1/4".
And try to get away from the mesh tape. Mesh tape needs to be installed with something like Durabond for the bed coat, or it almost always tends to crack later on.
Willie T
Old 10-02-2011, 04:07 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What is your frequency of nailing? How often did you nail the drywall? What is your nail pattern? Don't know how to ask the question.
I must be mis-understanding your first post. If what I am understanding is correct then you can expect the entire ceiling to come down on its own after a few rainy days.
Old 10-02-2011, 04:21 PM   #8
Old School
Willie T's Avatar
After a few beers today, I'm feeling humorous, Bud. He might answer like this:
Originally Posted by Bud Cline View Post
What is your frequency of nailing? About one job every three years, or so. How often did you nail the drywall? Every time I hung a sheet. What is your nail pattern? They're round, with flat heads. Don't know how to ask the question.
Sorry, I just get this bug sometimes. You know how it is.
Willie T
Old 10-02-2011, 04:24 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
LMAO
Makes my day. I was getting pretty bored here until now.
ROFLMAO
Based on what's been done so far you could be right.
The Following User Says Thank You to Bud Cline For This Useful Post:
Willie T (10-02-2011)
Old 10-02-2011, 04:29 PM   #10
Old School
Willie T's Avatar
I know this is a DIY forum, but wouldn't you think that if someone went to HD, and saw 1/4", 3/8", 1/2", 5/8", Fire Rated, Ceiling Rated, Cement Board, Blue Board, Green Board, etc in all these different piles that he just might be inclined to think that perhaps he needs to arm himself with a tad more information about all this drywall stuff before launching into such a major undertaking as a ceiling?
Willie T
Old 10-02-2011, 04:39 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nope!
Not with what I see here on a daily basis. It's no different than building a bridge over a creek with Lincoln Logs.
Old 10-02-2011, 04:58 PM   #12
Wow, not the responses I was looking for!
Old 10-02-2011, 05:01 PM   #13
Rewards Points: 150
Next time post project before beginning. Then you will get priceless free advice.
Old 10-02-2011, 05:15 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why not?
Did you come here to be lied to and told what good job you had done? Be careful walking in that garage, that ceiling could come down at any time. You still haven't answered my questions about the nailing schedule you used. How is it all nailed?
Do DIY'ers think that these DIY Forums are populated by only unknowing DIYers that will praise someone for not doing their homework BEFORE they start a project?
This place is full of experienced professionals in every field of the building trades that know their stuff, one should expect to be "set-straight" when they do silly things.
Old 10-02-2011, 05:20 PM   #15
Rewards Points: 150
You could do a diy(1xs) coffered ceiling grid over the boards to hold them up.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
