Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-16-2012, 03:33 AM   #1
Carport walls
What are carport walls made of? I am trying to replace the wall that has a hole in it and it looks like the material is drywall and acoustic spray can it be repaired with stucco?
AmirZaahir is offline   Reply With Quote
Old 04-16-2012, 08:43 AM   #2
bubbler's Avatar
Carport walls
Carports are usually open to the elements, drywall seems like a bad choice due to potential for moisture or humidity.
How about a close up picture of the damaged material? Would make it easier for someone to identify it.
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Old 04-17-2012, 12:04 AM   #3
Drywall contractor
Carport walls
Open carports generally have wood on the walls, drywall on the ceiling is likely (though not a good product as stated above). If you are speaking of an actual enclosed garage as opposed to a carport (different names in different areas) it's very likely drywall on the wall. Drywall and stucco are completely different products. Drywall is best used as an interior application and stucco is normally an exterior application.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 10:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
