Can You Mud Over Wood? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 08:09 PM   #1
bigcaat's Avatar
Can you mud over wood?
We just moved into a former foreclosure which has become a moneypit and a headache. Neither my husband nor I are very handy, but we have been screwed out of so much money from contractors and carpenters, we have resorted to trying to do some things for ourselves.
My husband was trying to add some depth to a closet opening so we could put some bifold doors there. After several problems, he finally got it all framed, drywalled and beaded, then realized he was still short. Fed up and frustrated, he just removed the beading, framed two more pieces of wood on top of the already placed drywall and beaded the wood. It was my job to tape and mud, since I know how to do that.
I think he should have removed the drywall and placed the wood underneath, but he was so frustrated and spent so much time, i wasn't going to press the issue.
I am taping now, however, and am wondering if I'm going to have problems getting the mud to adhere properly to the wood frame. Also, there's a rather large gap on the inside of the closet between the beading and the wood. It won't be viewable, but it's a big gap - maybe a quarter inch.
Does anyone have any input on whether or not I can mud and texture that wood? Any other input would be appreciated as well.
Thanks,
Caat
bigcaat is offline   Reply With Quote
Old 09-29-2010, 10:00 PM   #2
Rewards Points: 1,910
I've seen plywood/wallboard joints successfully taped and mudded. Regular lumber (2x or 1x) might still shrink a little and crack the mud after a while but who knows I've never tried it.
What is beading? I take it you aren't doing jambs and casing?
Old 09-29-2010, 11:48 PM   #3
bigcaat's Avatar
Thanks. We will give it a try. It can't be any worse than the pitiful job that most of the workers have done in this house. Not sure how we'll deal with the overlap, he may just have to cut that down.
Jambs and casing? I think so. It's the metal strip that goes along the corner to give it a sharp corner for the mud. Maybe I should have called it corner bead?
http://homerenovations.about.com/od/...rcornerbea.htm
Old 09-30-2010, 12:21 PM   #4
Your best bet is to not mud over wood. It will eventually crack. If you can't affix a piece of drywall, at least use mesh tape on top of the wood and then mud. With respect to the gap from your corner bead o your drywall, you should have 2 inch tape. Use it.
unlvrebel is offline   Reply With Quote
The Following User Says Thank You to unlvrebel For This Useful Post:
bigcaat (10-04-2010)
Old 10-04-2010, 09:32 AM   #5
bigcaat's Avatar
Thank you, rebel. If I had the muscle to do it, I would just take off the end and switch the drywall and wood pieces. (Since he had it finished previously, but then realized it was still to wide.) I, however, have had several back injuries and don't have that kind of strength. When asked if I wanted to take over the project, my resounding answer was 'no.'
So, I have double taped all gaps and wood pieces - we will hope for the best.
Thanks for your input.
Caat
Old 10-04-2010, 10:05 PM   #6
jschaben
Rewards Points: 502
Caat
Hi Caat - Good Luck. I was going to suggest a small bead of polyurethane foam in the crack. Cut off any foamout and mud over that.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 07:46 AM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 12:42 PM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
