Can Topping Compound Go Bad? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 04:00 PM   #1
Rewards Points: 1,010
Can topping compound go bad?
I decided to patch some small holes in the wall today and I went to open a tub of Lafarge low-dust all purpose joint compound, and after I opened it, I looked like this ---->
It STUNK.
The tub is maybe a year or two old and was tightly sealed and kept indoors. There are no funky stains or colors in it, and it still has the right consistency, but it just smells so awful I don't want to use it. Does that stuff go bad over time? Should I pitch it?
spaceman spif is offline   Reply With Quote
Old 09-29-2012, 04:45 PM   #2
Sparky
Rewards Points: 510
yes it can spoil, usually grows mold eventually, you should only buy enough pre mix for what you're doing.
Techy is offline   Reply With Quote
Old 09-29-2012, 07:51 PM   #3
Drywall contractor
Rewards Points: 1,070
Yep! It will spoil. Usually in way less than a year...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-01-2012, 08:17 AM   #4
Rewards Points: 5,978
You can stop this from happening or at least greatly slow it down by before you put the lid on put a little bleach in some water (enough to cover the mud) then seal it tight. Just remember to pour it off before you stir and reuse the mud.
ToolSeeker is online now   Reply With Quote
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 03:59 AM
topping compound types tns1 Drywall & Plaster 5 10-31-2010 12:39 PM
Spackle Properties and favorite topping compound mobiledynamics Drywall & Plaster 0 08-22-2010 08:32 PM
What type of topping compound to use in bathroom? spaceman spif Drywall & Plaster 4 08-15-2010 02:27 PM
