Can Spraying Orange Peel Cover Up A Knock Down Textured Wall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 02:22 PM   #1
Can spraying orange peel cover up a knock down textured wall?
We have a 1 1/2 story Victorian that has knockdown textured walls throughout. I would like smooth walls more in keeping with the home's style, but it would be very expensive to have that done and my husband and I are not talented in that department. Can orange peel be sprayed on to cover and smooth the appearance of the stucco-like wall?
Hosanna is offline   Reply With Quote
Old 08-14-2010, 08:53 PM   #2
Drywall contractor
Rewards Points: 1,070
Orange peel is a much "lighter" texture than knock down. No it won't cover unfortunately.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-26-2010, 09:43 AM   #3
I assure you, you can do it yourself, it just takes time (lots of it). My boyfriend and I have a rougher more rigid type of texture than knock down and we are skim coating over it. Neither one of us has done it before either. We are on coat #4 of drywall compound and we are seeing nice smooth surfaces. It has taken us about 2-3 weeks doing it between 2-6 hours a day ( although we did miss a day here or there) The final result is worth it though.
Valerie1c is offline   Reply With Quote
Old 08-26-2010, 10:46 AM   #4
Old School
Willie T's Avatar
Interestingly enough, knockdown over orange peel is a finish I use quite a bit (discovered it by accident when I did some orange peel that was really supposed to be knockdown), and it is sharp, filling in a lot of the "dead", flat spaces. I've never tried it the other way around.
Willie T
How to best cover weep holes on a brick wall smcmurrey General DIY Discussions 27 10-12-2011 10:33 PM
orange peel when painting cabinets ponch37300 Painting 8 04-16-2009 10:55 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Painting ceiling and wall (2 diff colors) when both are textured lavee383 Painting 4 07-21-2008 10:28 PM
