Can One Person Drywall Cieling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 09:46 AM   #1
Can one person drywall cieling?
Must drywall over good sized popcorn ceiling. Any way that one man can do this himself? Must I rent one of those scissor lifts? How to raise the 1/2" drywall and hold it while I start the screwing?
JackMitchener is offline   Reply With Quote
Old 10-17-2013, 10:00 AM   #2
Rewards Points: 20
There ae several methods for one man to install drywall to a ceiling. In my opinion the easiest and least frustrating is the use of a drywall hoist, particularly if you are new to hanging drywall. By scissor lift did you mean a man-lift?
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
JackMitchener (10-18-2013)
Old 10-17-2013, 11:05 AM   #3
Rewards Points: 5,974
Either buy or rent a lift. Why not just remove the popcorn?
Old 10-17-2013, 01:39 PM   #4
747
registered
747's Avatar
Rewards Points: 534
exactly go rent a drywall lift.
747 is offline   Reply With Quote
Old 10-17-2013, 02:47 PM   #5
Registered User
Rewards Points: 5,212
There are a few without the lift, as you asked for; http://www.youtube.com/results?searc...be.sQmB5QJDUcE
Use "lightweight" drywall...
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 10-17-2013, 02:51 PM   #6
Gymschu's Avatar
Rewards Points: 466
http://www.harborfreight.com/drywall...ist-69377.html
Or you can rent one for 50 dollars a day......
Gymschu is online now   Reply With Quote
Old 10-17-2013, 03:34 PM   #7
Rewards Points: 13,270
No way would I be dry walling over popcorn!!
It needs to go any way so why not just remove and skim coat the flaws.
Old 10-17-2013, 04:56 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Drywall lift....I got mine off CL for $125. I'm sure I can sell it for $100 once I'm done....which reminds me...I think I'm done with it.
Here is a pic of me lifting a 4'x12' of 5/8" drywall up 11'
The only help I've had was lifting the sheets up onto the lift.
Old 10-17-2013, 05:14 PM   #9
K&B Designer
Live_Oak's Avatar
Heck, even I own one of these!
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 10-17-2013, 05:38 PM   #10
Rewards Points: 626
looking for a extension to do a 18 foot tall ceiling the only extension I can find will get me to 15' ugh.
Nailbags is offline   Reply With Quote
Old 10-17-2013, 07:07 PM   #11
DIY staff
Rewards Points: 7,174
You may need to rent a lift with the extension----
Old 10-17-2013, 08:29 PM   #12
Davejss's Avatar
Rewards Points: 740
I just use a deadman. A 2x4 or other lumber with a board nailed to the end. I lean the deadman at an angle, lift the sheet of drywall onto the deadman, push up the other end and I'm good to go. A drywall lift, or gypsy jack as we call them in my parts, is even easier, but there are plenty of one man crews like me that use the deadman method.
Davejss is offline   Reply With Quote
Old 10-17-2013, 08:30 PM   #13
Rewards Points: 3,130
Yes, one person can drywall a ceiling. But the one person will NOT be me! Forty years ago maybe; not now LOL.
The Following User Says Thank You to md2lgyk For This Useful Post:
Gymschu (10-21-2013)
Old 10-17-2013, 08:53 PM   #14
Please post a video, I would really like to see. I don't know about your area but mine you can rent a lift for $20 a day. They are safe, and easy to use, and cheap when you consider the cost of doctors after the accident.
Old 10-17-2013, 10:21 PM   #15
Rewards Points: 216
i got mine off CL also. $100 like new. when i am done with it, back on cl for $100.
same as in the above pics.
Fix'n it is offline   Reply With Quote
Tags
ceiling , drywall , lift & hold , one man
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Drywalling: which way to go: 2 people or 1 person and a drywall lifter? KUIPORNG Remodeling 19 10-24-2006 09:42 AM
