Can I Use The Other Side Of Drywall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 05:15 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Can I use the other side of drywall?
Can I use the other side of drywall as the front?
I have a piece of drywall that my dad needs and on the right side I practiced doing a texture and was wondering if I can use the other side.
Will the drywall screws go in the same and will the mud adhere?
Thanks very much.
yummy mummy is offline   Reply With Quote
Old 05-01-2010, 05:24 PM   #2
Thanks very much.
No! Dry wall is cheap and it will be less of a problem if your Dad has a new piece to work with!
Old 05-01-2010, 09:17 PM   #3
Thanks W. I will send him out and purchase some.
Old 05-03-2010, 09:31 AM   #4
Drywall contractor
Rewards Points: 1,070
You COULD use the back side, but the backing paper is much coarser/rougher than face paper and the entire surface would have to be glaze coated and sanded prior to paint. Easier to buy new.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
yummy mummy (05-05-2010)
Old 05-03-2010, 08:41 PM   #5
you can use the backside it just has to face the studs
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
cellophane (05-05-2010)
Old 05-03-2010, 11:38 PM   #6
Just like laying grass sod! The brown side faces the earth!
Old 05-03-2010, 11:41 PM   #7
I might use it in a closet or somewhere it will be covered
--behind kitchen cabinets etc
Old 05-05-2010, 08:14 AM   #8
Next Time...New Build
Rewards Points: 150
That was awesome.
RickyBobby is offline   Reply With Quote
Old 05-05-2010, 04:37 PM   #9
a comedian is born everyday......
Condo Bathroom Reno (CBU, Drywall, tiling, basic plumbing) LeviDIY Project Showcase 37 11-05-2014 02:16 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 01:24 AM
Question about putting up drywall CZ DIY Building & Construction 5 02-25-2010 10:41 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 06:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
