Can I Use 1/4" Drywall On A Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-20-2009, 10:48 PM   #1
Can I use 1/4" drywall on a ceiling?
I've got a very large cathedral ceiling area that needs to be drywalled. Those 1/2 sheets are pretty heavy... so is there a reason why I couldn't use 1/4" to make a miserable job like this a bit easier? I have to hire someone to do this so in theory it could cut down on the cost for labour too. Your thoughts?
churchlady is offline   Reply With Quote
Old 11-20-2009, 10:54 PM   #2
How far apart are the joists ?
1/2" is good up to 16" as I recall
not sure on 1/4"
Old 11-20-2009, 11:29 PM   #3
FYI Scuba D: They're 16" joists
Old 11-21-2009, 05:58 AM   #4
Don't do it. If you're hiring a competent drywall person, 1/2" will not be a problem.
jerryh3 is offline   Reply With Quote
Old 11-21-2009, 07:04 AM   #5
ccarlisle's Avatar
From a labour cost point of view, it makes no difference. However, 1/4" will sag more and will show depressions etc more than stiffer drywall. Go with 1/2"...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 11-21-2009, 08:25 AM   #6
Rewards Points: 5,336
For a cathedral ceiling, you will want to use a drywall lift ,so weight should not be an issue. 1/4" drywall is only good to install over another solid base.
Ron
Old 11-21-2009, 08:09 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
If this is for the church ceiling in your other posts, you definitely want 1/2". I think you planned on putting insulation above this as I recall. Depending on how much insulation you are loading above this, you may even want to think about using ceiling board, or jumping up to 5/8"
Old 11-21-2009, 08:54 PM   #8
I think 1/2" ceiling board is REQUIRED if it is to be holding up insulation. If there is no insulation being held up, normal 1/2" is the way to go.
the carpenter is offline   Reply With Quote
Old 11-22-2009, 06:24 AM   #9
Remodeling Contractor
Use 1/2" at least. 1/4" is only used to cover over existing damaged surfaces or built up curved walls.
Old 11-23-2009, 11:28 PM   #10
Thanks for all the input you guys. I was hoping to get away with that 1/4" but it sounds like a bad idea now! Oh well.
PS Maintenance 6: What is "ceiling board"?... Maybe I've been living under a rock but I haven't heard of it.
Old 11-24-2009, 07:35 AM   #11
Rent
CHURCHLADY
Rent a drywall lift then you don't have to worry about weight as much.
let the lift do the work.
Sorry did not read post #6 close enough, got to check glasses.
SULTINI is offline   Reply With Quote
Old 11-24-2009, 01:34 PM   #12
Guess it wasn't a sheet"rock" you were living under. It is 1/2" thick drywall that is manufactured to allow higher loading, such as insulation, without sagging. It is lighter, of course, than 5/8", but will still allow you to place a substantial load of insulation per square foot.
Old 11-25-2009, 08:43 AM   #13
295yards's Avatar
Learned something new!
I thought ceiling board was 5/8 drywall
295yards is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Drop Drywall Ceiling JasonS Drywall & Plaster 3 09-27-2009 01:57 PM
Ceiling drywall cracking and popping sound DoubleM Drywall & Plaster 7 12-17-2008 02:13 PM
ceiling drywall question DangerMouse Drywall & Plaster 5 10-17-2008 01:32 PM
Plaster Ceiling and drywall dprasan Remodeling 6 02-05-2008 11:34 PM
