Can I use 1/4" drywall on a ceiling?
I've got a very large cathedral ceiling area that needs to be drywalled. Those 1/2 sheets are pretty heavy... so is there a reason why I couldn't use 1/4" to make a miserable job like this a bit easier? I have to hire someone to do this so in theory it could cut down on the cost for labour too. Your thoughts?
How far apart are the joists ?
1/2" is good up to 16" as I recall not sure on 1/4" |
FYI Scuba D: They're 16" joists
Don't do it. If you're hiring a competent drywall person, 1/2" will not be a problem.
From a labour cost point of view, it makes no difference. However, 1/4" will sag more and will show depressions etc more than stiffer drywall. Go with 1/2"...
Ron |
If this is for the church ceiling in your other posts, you definitely want 1/2". I think you planned on putting insulation above this as I recall. Depending on how much insulation you are loading above this, you may even want to think about using ceiling board, or jumping up to 5/8"
I think 1/2" ceiling board is REQUIRED if it is to be holding up insulation. If there is no insulation being held up, normal 1/2" is the way to go.
Use 1/2" at least. 1/4" is only used to cover over existing damaged surfaces or built up curved walls.
Thanks for all the input you guys. I was hoping to get away with that 1/4" but it sounds like a bad idea now! Oh well.
PS Maintenance 6: What is "ceiling board"?... Maybe I've been living under a rock but I haven't heard of it. |
Rent
CHURCHLADY
Rent a drywall lift then you don't have to worry about weight as much. let the lift do the work. Sorry did not read post #6 close enough, got to check glasses. |
I thought ceiling board was 5/8 drywall :laughing: |
| All times are GMT -4. The time now is 04:59 PM. |
