Can I Mud A Small Repair Without Tape - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 04:05 PM   #1
Can I mud a small repair without tape
I have an area on the ceiling of the garage where something I stored in attic moved the drywall joint and popped the tape. I have installed a backup board to secure the joint. When I removed the bad tape, the old mud and paint to the exact width of the tape came off. Now I either need to mud without tape or scrape, sand or file a wider area in order to install new tape.
Any thoughts would be appreciated
akshack is offline   Reply With Quote
Old 04-28-2011, 04:29 PM   #2
Old School
Willie T's Avatar
Cut your new tape a half inch or so narrower with a pair of scissors.
Willie T
Old 04-29-2011, 01:03 PM   #3
Thanks. I hate to say this but my wife came up with the same thought before I told her of your reply.
Old 04-29-2011, 04:09 PM   #4
Old School
Willie T's Avatar
Obviously a smart woman.
Willie T
Old 04-30-2011, 11:35 PM   #5
Too Short? Cut it Again!
Hugh? You need to subfloor that attic if you plan to store heavy stuff. Drywall is not meant to be a load bearing material. And remember it is hanging my screws and nails to the bottom side of the ceiling. No wonder you popped a tape joint if you stored something heavy on only the drywall from above.
You need some plywood or other planking in the space above. Then, without seeing your situation, I would plan on doing a cutout of dryall, screwing it in place, taping and mudding. Prime and paint.
Old 05-01-2011, 03:06 PM   #6
You have to replace the tape or the joint will crack down the road at some point.
Dan
dberladyn is offline   Reply With Quote
Old 05-03-2011, 04:25 PM   #7
thanks
thanks for the help
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 04:45 PM
How do I repair 1) loose drywall tape & 2) "nail pops"? Michael Allen Drywall & Plaster 4 04-24-2011 01:37 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
using caulk instead of tape on hairline cracks.. windowguy Painting 2 04-15-2009 11:27 PM
Small grumbling cement repair deck hand Building & Construction 6 03-28-2009 10:52 AM
