-   -   Can I mud a small repair without tape (http://www.diychatroom.com/f101/can-i-mud-small-repair-without-tape-103033/)
akshack 04-28-2011 04:05 PM
I have an area on the ceiling of the garage where something I stored in attic moved the drywall joint and popped the tape. I have installed a backup board to secure the joint. When I removed the bad tape, the old mud and paint to the exact width of the tape came off. Now I either need to mud without tape or scrape, sand or file a wider area in order to install new tape.
Any thoughts would be appreciated:confused1:
Willie T 04-28-2011 04:29 PM
Cut your new tape a half inch or so narrower with a pair of scissors.
akshack 04-29-2011 01:03 PM
Thanks. I hate to say this but my wife came up with the same thought before I told her of your reply.
Willie T 04-29-2011 04:09 PM
Obviously a smart woman.
user1007 04-30-2011 11:35 PM
Hugh? :no::no::no: You need to subfloor that attic if you plan to store heavy stuff. Drywall is not meant to be a load bearing material. And remember it is hanging my screws and nails to the bottom side of the ceiling. No wonder you popped a tape joint if you stored something heavy on only the drywall from above.
You need some plywood or other planking in the space above. Then, without seeing your situation, I would plan on doing a cutout of dryall, screwing it in place, taping and mudding. Prime and paint.
dberladyn 05-01-2011 03:06 PM
You have to replace the tape or the joint will crack down the road at some point.
Dan
akshack 05-03-2011 04:25 PM
thanks
thanks for the help
