Can I Fill/finish A Gap Over Spray Foam? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 11:41 PM   #1
Rewards Points: 105
can i fill/finish a gap over spray foam?
quick random question, will joint compound or plaster (structolite) bond to cured spray foam, say in a gap about 1" wide, 1/2 deep?
redline9k is offline   Reply With Quote
Old 01-04-2012, 11:44 AM   #2
you need to use a hard setting compound for gaps that size that dry in 20, 45 or 90 minutes. pros call it (hot mud) you can buy at lowes or HD and can get them in a small box instead of having to buy a large bag. 20 is green 45 is red and 90 is blue in usg or cgc
good luck.
LR
luckyrabbit is offline   Reply With Quote
Spray foam insulation troyce1 Insulation 12 12-14-2014 07:30 AM
using XPS and spray foam together in stud bay diybrad Building & Construction 5 08-06-2011 09:08 PM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 08:12 PM
