Can I Cover A Hole Successfully? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-28-2013, 12:04 PM   #1
Can I Cover a Hole Successfully?
My wife & I are redocorating our main bathroom and she wants to change out the recessed toilet paper holder to the holder that's just mounted on the surface. This means I have to cover a 5"x5" hole in the drywall and somehow put the orange peel texture to it. Is there any advice anyone can give me to get this done right or should I call a professional to handle this small task?
rrzrr is offline   Reply With Quote
Old 08-28-2013, 05:06 PM   #2
DIY staff
Rewards Points: 7,174
The patch should be simple enough--you will be feathering that out about 20" wide to hide the patch----to add the orange peal to that repair--use a long nap roller.1/2" should do--and a thick paint--two coats is usually needed to get enough build to blend the texture into the old paint.
rrzrr (08-28-2013)
Old 08-28-2013, 05:11 PM   #3
Rewards Points: 12,830
Since you have to patch the hole anyway I'd cut it out bigger and add a 2 X 6 between the two studs to have something to attach the new holder to.
It's just as easy to patch a big hole as a small one and it's all the same materials and steps involved.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
Gymschu (08-28-2013), oh'mike (08-28-2013), rrzrr (08-28-2013)
Old 08-28-2013, 08:37 PM   #4
Rewards Points: 5,974
Is the TP holder going in the same area if so I would go with Joe for adding support, I have never used Mike's method for orange peel I usually just use the rattle cans for a patch that small. Get the can that is adjustable there are 3 sizes of orange peel. Also sand the texture back from the hole if you put more texture on what is already there it will look bad.
The Following User Says Thank You to ToolSeeker For This Useful Post:
rrzrr (08-28-2013)
Old 08-29-2013, 09:07 AM   #5
Bill Kearney
Rewards Points: 1,174
It might help if you posted a picture of this 'orange peel' look. And I'm assuming you mean the new holder is going to be put somewhere other than where the current one is located?
What's the reason for getting rid of the existing one? Because larger rolls don't fit? They do make extenions for such rolls:
http://www.amazon.com/Charmin-Extend.../dp/B0045JAA7U
I used to see them included free with the rolls when the size first came out.
We used them for a couple of the built-in kind you mention. Worked great. Just know they usually work better if you put the rolls on so the paper pulls up. Some folks are picky about this, but roll-down won't work as well with the extensions.
wkearney99 is offline   Reply With Quote
Hole in clapboard allowing birds to nest GarfE Pest Control 1 04-16-2012 12:14 PM
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
Can I use a drywall patch to cover a hole where an old outlet box used to be stephroberson Drywall & Plaster 4 09-28-2010 08:25 PM
How to cover a hole in a floor slab tomseeley Flooring 2 11-16-2009 01:14 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
