Can I Build A Wall Out Of 4x4x8's? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-26-2010, 07:48 PM   #16
Rewards Points: 27
Originally Posted by Marty S. View Post
Steve if you don't want to attempt drywall a popular option is frame the wall and panel it.
I didn't even think about paneling, that's not a bad idea. I'm definitely going to consider that. When I start this job, i'll take before and after pictures
steve-19 is offline   Reply With Quote
Old 10-26-2010, 07:57 PM   #17
Registered User
Rewards Points: 4,924
If the room is to be used for a bedroom, you need egress: http://www.aacounty.org/IP/Resources...ementGuide.pdf
http://illowaicc.org/uploadedFiles/I...20Openings.pdf
The room also requires heat, natural light and ventilation. A 3' wide hallway is also the minimum safety code.
Gary
Old 10-26-2010, 08:05 PM   #18
Rewards Points: 27
Luckily, the room was previously finished, but a drain backed up and the basement flooded and the dry wall and frame had to be ripped down. There is already natural lighting and we need to tap into the duct for heat. The hallway, we are planning will be 3' 7"
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Correcting exterior wall build on slab KAdams4458 Building & Construction 12 08-23-2009 02:30 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Frost Build Up On Interior Garage Wall richw Building & Construction 8 01-06-2008 10:47 AM
