Can I Build A Wall Out Of 4x4x8's? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 10:59 PM   #1
Rewards Points: 27
Can I build a wall out of 4x4x8's?
I want to separate a basement room (10x18) into two 10x9 rooms. I did a search and found nothing on building wood walls. I basically want to take 21 4x4x8's and nail them to each other, and screw the first one into the floor with concrete screws. Then screw the last couple into the ceiling, or possibly leave a 1 foot gap so both sides are heated properly without running more duct-work. Is there a flaw to this design?
steve-19 is offline   Reply With Quote
Old 10-25-2010, 11:15 PM   #2
jlhaslip's Avatar
Rewards Points: 396
They will warp and check.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
BigJim (10-25-2010)
Old 10-25-2010, 11:17 PM   #3
Rewards Points: 27
even if i paint it with dry-block? Or seal it?
Old 10-25-2010, 11:24 PM   #4
Why would you do that VS framing a wall with 2x4's ??
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Axecutioner-B (10-26-2010)
Old 10-26-2010, 12:15 AM   #5
Rewards Points: 27
I've never done framing or drywall before, seems like it would take me longer to do the drywall
Old 10-26-2010, 12:21 AM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
nobody has until the first time. Your method will be more expensive and generally considered to be less attractive than a simply dividing wall made of 2X4 and drywall.
Old 10-26-2010, 12:26 AM   #7
Rewards Points: 27
I was also thinking of taking 2 4x8 sheets of plywood, building a frame on the floor to mount them in and nailing them to the basement ceiling, and then putting drywall over it... would this suffice?
Old 10-26-2010, 12:31 AM   #8
nap
You talking to me?
nap's Avatar
do you need an impregnable wall? There is nothing wrong with building a wall you can't run a car through if you need it. If you don't need it, it is merely a waste of money.
with the plywood, you would still want to run studs at 16" OC. Plywood flexes a lot without support and that means so would the drywall. Your joints would crack with that much flexing.
Old 10-26-2010, 12:35 AM   #9
Mabc's Avatar
X2
Just frame out a wall with 2x4's and finish with drywall.
Mabc is offline   Reply With Quote
Old 10-26-2010, 12:48 AM   #10
Rewards Points: 27
My sister is moving in with my parents while she recovers from surgery, I want to divide a basement room for them for two of her kids to share. I am looking for a dividing privacy wall.
What kind of money would I be looking at if i just did 2x4s and drywall?
I just did the measurements, the room is 13 feet long, but the ductwork comes in at 9' 5", so i would have to drop here (and this is where I would build a door)
Old 10-26-2010, 12:55 AM   #11
Mabc's Avatar
A picture or a drawn layout of the room would help for us to under stand what you're working with.
Old 10-26-2010, 03:23 AM   #12
Rewards Points: 27
Here's pictures of the current room, and what we need done. We want to divide the room in half and install framing for a door + a door under the ductwork
current room (below) The L-shaped thing is ductwork
what we need (below) Drywall right down the middle creating a 10'x13 and an 11'x13' room. We would need a door to access the 11x13 room.
What would be nice (below)... Drywall Down the middle, like above, but also a hallway with drywall down both sides, starting at the ductwork creating a 9.5'x13 and an 11'x13' room.
What we would really want (below)... Drywall the 13' wall, both 21' walls, make the hallway, make two rooms (9.5'x13 and an 11'x13' room)
Old 10-26-2010, 06:55 PM   #13
Steve if you don't want to attempt drywall a popular option is frame the wall and panel it.
Old 10-26-2010, 07:38 PM   #14
Rewards Points: 262
You will be better off building the frame in place rather than on the floor first to account for discrepancies in the plumb and level of your current walls, floor and ceiling that this wall will attach to.
How long are the kids planning to live in the basement? Moisture, mold and especially radon are important considerations if children will be staying there long-term.
Jim F is offline   Reply With Quote
Old 10-26-2010, 07:46 PM   #15
Rewards Points: 27
I'd say 6 months to a year.
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Correcting exterior wall build on slab KAdams4458 Building & Construction 12 08-23-2009 02:30 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Frost Build Up On Interior Garage Wall richw Building & Construction 8 01-06-2008 10:47 AM
